A good use for an S3 Virge ?
Reply 20 of 81, by Myloch
Carlos S. M. wrote:
Well, another use for the ViRGE can be as 2D card to be paried with 3Dfx Voodoos
This. S3 virge (DX/VX) + voodoo 1/2 was a very nice combo. It had some problems with direct3d games though, conflicts about what card to be used. Even "3D Control Center V1.0" doesn't work with some games.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 21 of 81, by sliderider
Elia1995 wrote:
I haven't taken a photo of it yet, it's like the one in the middle here […]
But I have none of the chips that go in the brown sockets, they're all empty.
Adding extra memory to a Virge would be a waste.
Reply 22 of 81, by Elia1995
Why ? The more memory, the faster it can perform... no ?
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 23 of 81, by nforce4max
The added memory allowed for better settings in windows but wasn't a big help in gaming in this era unlike previous generations.
Reply 24 of 81, by shamino
You normally want to have double buffering so that the video is smooth and not flickery, at least at the Windows desktop. With 2MB RAM this limits you to 1MB used for the video frame. With that budget you can run 800x600 16bpp or 1024x768 8bpp. If you upgrade the card to 4MB then you can double the video RAM usage and still get double buffering, so you'd get a nicer result with 1024x768 16bpp. Not that you'd want to do this in games, it's just a benefit for the Windows desktop.
I had a 4MB Virge in a Cyrix 6x86 back then. Hardly anything ever had acceleration support, but the last 3D game I remember running in an accelerated mode was "Premier League Football Manager 99". I had to turn off the textures on the players but then it would accelerate the game with flat shaded players running around. That was with a 4MB card - not sure if it would work at all with 2MB. But really, that game was too much for the card anyway and with today's prices on old cards you'd run it with something else.
Reply 25 of 81, by elianda
If it is for 2D games then 2 MB is sufficient on a ViRGE as on every other card at this time. This allows for 640x480 at 16 bit double buffered.
More memory is only useful for running higher resolutions/color depths. However the VirGE comes with a 135 MHz RAM DAC where for 4 MB 170 or 220 MHz would be better. So 2D image quality degrades faster than on the e.g. professional S3 Vision series.
Youtube Channel
Reply 26 of 81, by Elia1995
Now I wish it was VLB so I could immediately fix what happened today to my 486... 😢
Reply 27 of 81, by sliderider
The thing is, though, finding those RAM chips separately. Most likely you'd have to scavenge them from another Virge board.
Reply 28 of 81, by Jade Falcon
Rank BANNED
BANNED
Overclocking. I use my virge in my slot one bench setup.
Reply 29 of 81, by Tiger433
You can try Tomb Raider on that card, on 320x240 and 512x384 work good with that card, I have 4 MB S3 Virge and setting up in windows 1024x768x24 gets very blurry screen, that`s normal with that card?
And that`s photo of my card:
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 30 of 81, by shamino
I used to run Windows at 1024x768 on my Virge back in the 90s, but based on what elianda posted maybe some blurriness at that resolution might be normal. It was a long time ago for me so I can't really judge it's quality from such a distant memory. I didn't have a good monitor back then either so I may not have even known the difference.
Reply 31 of 81, by Tiger433
In 16 bits at 1024x768 I saw normal everything without blurring, but at 24 bits It was very blurry at screen, I saw that on CRT monitor and also on LCD.
My Youtube channel
Reply 32 of 81, by Elia1995
Still the S3 Virge is the only graphics card that gives me the gradients in the title bars right at the first boot already without any driver 😁
Reply 33 of 81, by stamasd
Chips are not that hard to find, or expensive.
http://www.ebay.com/itm/321424283082?_trksid= … K%3AMEBIDX%3AIT
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 34 of 81, by Carlos S. M.
ouch, dat 20 $ shipping
Reply 35 of 81, by stamasd
To the Canary Islands, perhaps. To the US it's $3.25
I/O, I/O,
I/O, I/O
Reply 36 of 81, by Elia1995
It's saying $22.50 for me 😳
Reply 37 of 81, by shamino
Strange. I'm confused why the color depth made a difference, since the video signal is analog anyway, and it seems like the blurring must be coming from the analog side of the card. Once the colors are converted into analog it seems like the digital color depth would no longer matter and the sharpness of the pixels would just be dictated by how well the circuitry can handle the resolution. I don't really understand analog electronics though, that stuff is voodoo.
Reply 38 of 81, by Tiger433
That setting use more memory than 16 bits in that resolution, added memory can cause that problem? In XP I can only set on that card max 1024x768x16 bits and I don`t see 24 bit setting, card was all time totally stable, in 800x600 in 24 bits also was good sharp image, in 1280x1024x16 bits was even more blurred than in 1024x768x24.
My Youtube channel
Reply 39 of 81, by Elia1995
Has anyone tried to connect an hdmi monitor with a vga to hdmi converter ?
