First post, by Neonstar
Hi there! I'm a student and an enthusiast (in my opinion) of computers and gaming. I've recently discovered all these Win 9x era games such as the early MechWarriors, Carmageddon and other games that don't run particularly well on my Win 10 64-bit main rig. I'm thinking of building a legacy gaming PC and dual booting a DOS and 98SE to play all of the classics from before my time. (1999) 😜
Basically I would appreciate input from any experienced users of legacy hardware on whether or not I'm mad, or if I'm picking the right components, doing everything right, etc.
From what I can gather, the essentials of 9x gaming is a Voodoo2 based card? What would be the best card to pair that with? I've got a friend who might possibly have a RIVA TNT or TNT2 to give me, but I'm still a bit dizzy over which cards did what. I attach a Voodoo2 to another card, and the Voodoo2 does all the 3D while the other card does all the 2D work? (I have quite a few Glide based games I want to play.) Should I use something instead of a Voodoo2? I've heard that newer Voodos, newer ATI Rage cards, and basically each new card lost compatibility with predecessor generations.
The CPU I've picked out at the moment is a ~2.4GHz Pentium 4 along with a motherboard and RAM that I scored for 50 bucks. I figured I can underclock it or use a CPU killer program if I need to play slower games; is this the right state of mind? 😀
Lastly, I'm still all over the place on a soundcard. There seems to be very mixed feelings over which AWExx card is the best, and I'm still between an SB16, a kind of AWE32, or a kind of AWE64. If I got an AWE I was going to expand the RAM to that card's capability and replace a few of the 'meh' sounding patches like the guitars in a custom soundfont. When I've got more money to burn, I was going to try and find a Roland Sound Canvas and use that to fuel my rages in Doom, Duke, and co. What are your opinions on the best soundcards?
That's about it really. The power supply, drives, RAM and all that extra stuff is already taken care of for the moment. How am I doing? (Stupid teens, right? 😁) Again, main OS is currently planned to be Windows 98 Second Edition (That and Vista are the only disk copies my family owns).
Reply 2 of 15, by Neonstar
Currently the site is down but I believe it had one ISA, one AGP, and three PCI slots. When it works again, I"ll update the OP with the motherboard specs.
Reply 3 of 15, by Trank
http://pc4u.org/wp-content/uploads/2016/03/SL … -voodoo-2-1.jpg
Here is how a Voodoo2 setup looks like(This is an SLI one though). You could pair a Geforce FX series card with the Voodoo2. Or, just buy a Voodoo 3 AGP and that card has 2d support for DOS Games. Great compatibly, but not sure if you want to run games from 2002/2003 cause thats where the card will not work great at all. (Seems you are mostly interested in the 90s)
In short, a Voodoo 3 2000 or 3000 could be the easiest and cheapest way to get the most of your system for that era.
Also when it comes to the Pentium 4 slow downing, while it will work in my opinion its the worst way to handle getting good compatibly. There are better ways to get good performance and great compatibly like with a AMD k6 III. Though the P4 is a lot cheaper and will do the job actually pretty good.
If you get an AWE get an ISA one by the way.
Reply 4 of 15, by PhilsComputerLab
With the P4, while it can work, I would build a dedicated Windows 98 PC, and leave DOS out. It can get a bit tricky.
Get the slowest P4 you can find, and then you will still run into some games that will run too fast. Windows 9x games range from games than need a Pentium and a Voodoo 1 to a fast Pentium III with a GeForce2.
The way I see it, very early Windows 9x 3D games are indeed best played with a Voodoo card. Compatibility is great, they are always mentioned in the readme files, many games have native Glide support and so on.
But anything more recent, let's say DirectX 6 games such as Shogu, Expendable, Drakan, IMO, you are better off with a GeForce. You get 32 bit colours and can muck around with AA and AF for eye candy. OpenGL games also work great on GeForce cards such as GLQuake, Quake II, MDK 2 and so on.
For sound, Aureal Vortex 2 sound chip for that awesome A3D surround over headphone 😀
YouTube, Facebook, Website
Reply 6 of 15, by Neonstar
Alright, so maybe try and downgrade to a Pentium III if I come across one? Also yeah dedicated 98 might be better. MS-DOS mode is probably good enough, now that I think about it. Based on your suggestions it sounds like the best way to go video wise is pair up a Voodoo2 and a Geforce FX, mostly because I've seen lots of threads where later Voodoos have had compatibility issues. Thanks for the help 😀
Reply 8 of 15, by PhilsComputerLab
The FX is so new that you have to use very modern drivers which introduce all sorts of glitches.
I would start with a cheap GeForce2 MX type card, try out the games and see how it all runs before hunting down specific hardware and potentially spending lots of money.
I'm not familiar with the games you mentioned, but if they support Glide, then a Voodoo 2 is a good addition. Because you got a P4, likely AGP Voodoo cards won't work for you I'm afraid.
Basically, the P4 is not the best choice for the type of games that you're after.
Reply 9 of 15, by Trank
NVIDIA GeForce FX 5800 Ultra
NVIDIA GeForce FX 5600 Ultra
NVIDIA GeForce FX 5600SE
NVIDIA GeForce FX 5200 Ultra
NVIDIA GeForce FX 5200SE
Can all use 45.23 Nvidia Drivers which most here will agree work perfectly. Also i forget about the old AGP thing with P4 boards. But it wont matter since a FX 5200 with a Voodoo 2 wouldn't be bad at all.
Reply 10 of 15, by PhilsComputerLab
It all depends on the games you are playing.
Quake II? Well that runs fine under Windows 7 anyway. Incoming? Only works correctly up to TNT2.
I found that the further away you go with drivers and graphics card from 1999, the more likely you run into an issue. You might never though, so it all depends on the games.
Reply 11 of 15, by Trank
That is true too. The further you go the worst it gets. But thats why having the Voodoo 2 there for those picky 3d games will work great.
I use a MX460 for games like Final Fantasy 7, X Wing Alliance that have issues with Texel Alignment.
Reply 12 of 15, by Neonstar
Yeah that era but not specifically Quake II (Although I might install my copy of it now that it's in my head.)
This is more for games that don't run properly under Vista/64bit and above systems. Mechwarrior 2, Wasteland, Mechbrigad, and Galactix, although I plan to chuck OG Quake, and other early Glide supporting games on as well.)
I might have scored a RIVA TNT2, so that could be good to go with a Voodoo?
Reply 13 of 15, by PhilsComputerLab
I wish I was familiar with these games, but as for the TNT2, absolutely! That is my go-to Windows 98 card from Nvidia. It competes with the Voodoo 3. Can't go wrong 😀
Reply 14 of 15, by brostenen
I think he will be better off, getting a GF4-ti4200 as the fastest card.
4200's are not running that hot, have plenty of performance for Win98 gaming.
And because they run more cold, they will last a bit longer than the faster GF4's.
FX cards seem to have some trouble at something.
If faster than GF4 is wanted, then I have had good luck with Radeon-9600/9800's.
TNT2's to GF2-GTS/Pro/whatever (just not mx) seem to be good cards.
Voodoo3 are good too, so is Voodoo2. For really early Glide, then go for V1.
Just keep in mind, that Voodoo1 have a barrier when looking at clockspeed.
(something I can not remember what exactly is, other members might help on this)
For soundcards, then try looking for something that you will need.
If OPL chip is a must, then be aware that AWE64 does not have it.
Shure AWE64 (standard/value) are cheap, so it will not hurt the budget getting one.
Just to test, if you like the emulated OPL part of the AWE64.
Else.... Go for something like SB16/YMF-718/YMF-719 and a daughterboard.
Wich is more geared towards older Dos games.
When looking for PCI soundcards, people usually prefer three options, wich are:
YMF-724, Vortex2 and SB-Live. Personally I prefer YMF-724 cards.
The waters are more or less devided on PCI soundcards, here on Vogons.
Reply 15 of 15, by candle_86
I'd shoot for something like this for pure 9x gaming
Athlon XP
512mb Ram
32gb SSD
PCI Sata Card
Large 250gb+ Sata drive for ISO/File Storage
Geforce FX/4/3 Radeon 8500/7500
Voodoo 2 SLI
You will find you will run any game for Windows 9x up to about 2004 games like Call of Duty or other Quake 3 engine games that have issues with multicore.
