SB16 Emu on Live! Not Being Detected By Windows
First post, by Trank
Obliviously i dont use this PC mainly for DOS games. But i like the SB16 Emu. After i unistalled 98se and went with ME cause it works a lot better on my system the Emu cant be found. Even on a XP install it wont detect it, and ive gotten the SB16 to be detected on XP before. Anyone have any idea why?
Reply 1 of 21, by Jorpho
This question is confusing. What are you using to detect the "SB16 Emu" ? And what model of Live are you using?
Reply 2 of 21, by Trank
Sorry, i mean that windows itself does not see the SB16 Emu at all. Yet i have been using it for 2 years before this install of windows. Its one of the Value models.
Ive uninstalled and completely cleaned out the drivers. Moved the card to different PCI slots.
Reply 3 of 21, by Jorpho
Still not clear. What are you looking at exactly in order to determine that "windows itself sees the SB16 Emu" ? Are you looking at Device Manager? What are you looking at in Device Manager?
Reply 4 of 21, by Trank
Yeah in device manager everything about the Live is there. Gameport, WDM driver. All that, but no matter what it will not detect/install/recognize that there should be SB16 emu. Its just not there at all.
Reply 5 of 21, by Jorpho
What, exactly, are you seeing in the device manager in Windows 98 SE that you are not seeing in Windows ME?
More importantly, is there any particular DOS program you have been able to run with sound under 98SE that does not work in Windows ME?
Reply 6 of 21, by Trank
The Sound Blaster 16 Emulation. I need it so most of the DOS games will actually get some decent music. All of my DOS games run perfect but without the SB16 Emulation most of the games are either general midi or no sound at all.
Reply 7 of 21, by archsan
OP probably meant that this (virtual) device is missing: "Creative SB Live! SB16 Emulation".
Another Sound Blaster Live! SB16 Emulation thread
I can't comment much about getting it to work there though. Try some other drivers, from The LiveWare 3 CD maybe.. dunno. Good luck.
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 8 of 21, by Trank
Yes, thats whats missing exactly. Ill try that thank you.
Reply 9 of 21, by Imperious
The SB16 emulation part doesn't show up under sound and game controllers I think, but elsewhere in the list.
http://gillius.org/grfx/setup1.gif
Reply 10 of 21, by brostenen
When under Win98, it sometimes help installing liveware3, removing all of the Live devices and rebooting. Then win98 will install everything again, including SB16.
Reply 11 of 21, by Stretch
Are you using WDM or VxD drivers? Try VxD drivers.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound BlasterX G5
Reply 12 of 21, by Trank
Sadly Liveware3 just caused horrible issues. Not sure if i can get VxD under ME. Am i wrong?
Reply 13 of 21, by Trank
Strech was right, all i did was just force it to use the VxD drivers and SB16 emulation popped right up. Thank you for the suggestions.
Reply 14 of 21, by archsan
Yeah, I should be more specific. I meant the vxd from Liveware 3.
SB Live! Liveware 3.0 CD
So, what CT model do you have and which vxd version works with it?
Reply 16 of 21, by archsan
Well, in that case, Jayceebee said in the linked thread above that LW3 version won't work with it anyway. Noted for future reference. 😀
Reply 17 of 21, by Trank
Ah good thing i tried something else then, Cool.
Reply 18 of 21, by simbin
Coincidentally, I'm working with SB16 Emulation recently and have a minor issue with one of my games. I don't hear gunfire sounds during the Duke Nukem II into scene and I think some explosion sounds are missing from the game. I'm using IRQ5. Enabling Adlib makes gunfire sounds work in the game but still not during the intro scene. Music and other sounds are working. I'm not sure if it's a SB16 Emulation issue or just my configuration. Could you try and see if you experience the same issue? Duke Nukem II has a shareware version if you don't already have the game. thanks
WIP: 486DX2/66, 16MB FastPage RAM, TsengLabs ET4000 VLB
Check out my Retro-Ghetto build (2016 Update) 😀
Commodore 128D, iBook G3 "Clamshell"
3DO M2, Genesis, Saturn, Dreamcast, NES, SNES, N64, GBC
Reply 19 of 21, by Jorpho
The thread at Duke Nukem 2 ADPCM fix? would seem to pretty much indicate that your problem is utterly and completely unrelated to Mr. Trank's problems with Windows.
