What is this card?
First post, by stamasd
Found this mystery card while browsing ebay:
http://i.ebayimg.com/images/g/nJMAAOSwaB5Xumyy/s-l1600.jpg
http://i.ebayimg.com/images/g/kz0AAOSwV0RXumzb/s-l1600.jpg
Looks like a sound card with audio jacks and volume control, but there's also a connector resembling a VGA one on the bracket. It also appears to have SCSI on-board. It has a YMZ263 chip, the same digital audio chip used on the AdLib Gold. It also has a OPL3 chip.
Any ideas? The only reference I could find is this: https://fccid.io/JDF-SOUNDMEDIA001 and there isn't really any information there except that it was registered with the FCC as a sound card.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 1 of 19, by shamino
I don't know anything about that card but I think it could still be a MIDI connector just with an unusual choice for the connector type. Maybe it even breaks out into a normal joystick port, but even if that's the case you'd probably never find the original breakout cable. The only chance would be if a pinout were found and you could make your own.
Also.. the FCC web site has Amazon affiliate links? That's hilarious. 😀
Reply 2 of 19, by stamasd
Um, no that's not the real FCC site. Why would a government agency use a .io domain? I know and use the real FCC site frequently (ham radio-related).
I/O, I/O,
I/O, I/O
Reply 3 of 19, by keenmaster486
Absolutely no idea. Plug it into something and see if the OPL3 chip works!
Maybe it's some kind of cheap SB Pro II or 16 clone.
Could you post a picture of the front of the jacks?
World's foremost 486 enjoyer.
Reply 4 of 19, by stamasd
I don't have the card, I just found the auction that lists it... no other pictures of the bracket.
I/O, I/O,
I/O, I/O
Reply 5 of 19, by brostenen
It is without any doubt a soundcard.... There is a jumper "game" on it.
That special vga-look-a-like connector, might be a connector to hook up an external box of some sort.
Reply 6 of 19, by gdjacobs
It's a high density 15 port connector, so maybe some special type of game port breakout?
Reply 7 of 19, by stamasd
Interesting, the LMC835 is a stereo 7-band equalizer... sounds better that the standard bass/trebble controls on a regular SB.
But of course without tracking down some appropriate drivers, it's moot.
I/O, I/O,
I/O, I/O
Reply 8 of 19, by Robin4
Its a soundcard with a SCSI 50pin connector on board.. Scsi is needed to attach SCSI CD-roms to.
Reply 9 of 19, by darry
The chip below the LMC835 is hard to read, but looks like a SC87C51CCA44 which is an MCS 51 type micro controller .
Reply 10 of 19, by luckybob
the TMC 950 is a very standard 8 bit isa scsi controller. There are 16 bit versions, but it was only for IRQ reasons. If I was engineering the card, for *insert stupid upper-management decision here* reason, to save space I can see myself using a svga connector instead of the standard d-sub 15. I would do my best to make it a 1-1 pinout. If they used a stupid pinout so you MUST buy their overpriced special cable because of *insert stupid upper-management decision here*. I would not be surprised at all.
Reply 11 of 19, by Anonymous Coward
Maybe it's an OEM version of an ATI Stereo FX card....but those cards didn't have that extra yamaha chip. Anyway, that is the card this one reminds me of most.
Reply 12 of 19, by oerk
Nah, it's lacking all the chips needed for a video card.
Reply 13 of 19, by keropi
it's just a yamaha-based sound card with OPL3 and scsi connector , one would need a port converter to plug a joystick...
more pics at the auction : http://www.ebay.co.uk/itm/201651544231
YMZ263B-F datasheet: http://pdf1.alldatasheet.com/datasheet-pdf/vi … /YMZ263B-F.html
Reply 14 of 19, by Scali
That is also my guess. It looks like they had trouble fitting the volume knob and all the inputs-outputs on the back, so they used a smaller VGA-style connector rather than the regular 15-pin D-sub connector for the joystick/gameport. The card probably came with a simple converter back to regular 15-pin.
Reply 15 of 19, by Anonymous Coward
I was referring to ATi's stand alone soundcard, not the one with video...I think the one you have in mind is the VGA Stereo FX.
So are there other cards based on this Yamaha chip? This is the first one I've seen that predates the YMF-71x series. I wonder if it's SB Pro and WSS compatible. No mention at all in the datasheet. Or is it just a codec like on those OPTi based cards?
Reply 16 of 19, by keropi
the datasheet states that all you need to build a soundcard is this IC and OPL2 or OPL3 (well you also need glue logic and opamps - that goes without saying 🤣 ) , it offers playback/recording/uart midi and joystick functions... most likely it's a SB Pro compatible chipset as well...
Reply 17 of 19, by oerk
Whoops, sorry!
Reply 19 of 19, by peklop
YMZ263B-F, same chip as ADLIB GOLD?
Have someone saved pictures from auction and can reupload them?
Thanks
