First post, by synrgy87
Unsure if this is the right place to put this post, but if not, Sorry 😁
I am currently building a Pentium II 266 MMX based slot 1 system, with a Cezch(i think?) made motherboard which i believe to be the ASKA SST-5721
It's an ebay purchase, using it because it came with the I/O shield and ticks all the boxes AGP slot PCI slots, ISA slots, IDE/ Floppy, Slot 1, ATX form factor, SDRAM support and Intel I440BX chipset
So basically I'm looking for the manual, can't seem to find it online anywhere, Does anyone here know this board or have the manual?
it's only seeing 64mb of ram (known good memory) of a 128mb stick, and has an annoying standby feature when power button is pushed that I'd like to disable, there's also a few jumpers which are not labelled / not labelled too well on the board.
Reply 1 of 3, by darry
archive.org comes to the rescue with data from the now defunct http://www.aska-hk.com
No manuals (section seems empty), but a marketing info pdf and BIOS updates .
Be careful and choose the right one according to your BIOS string and/or clock generator model :
05/04/2001-440BX-PC87351-2A69KV3QC-00 B0504nag.BIN
12/13/2000-440BX-ITE8671-2A69KV3OC-00 B1213iag.BIN
11/20/2000-440BX-ITE8671-2A69KV3IC-00 B1120IAG.BIN
Hope this helps
https://web.archive.org/web/20040202064118/ht … t/Cata/5721.pdf
https://web.archive.org/web/20030831123539/ht … tial.htm#i440bx
and if the updated BIOS does not fix the RAM compatibility, I believe BIOS Patcher 4.23 has some memory size fixes .
Reply 3 of 3, by synrgy87
Awesome, Thanks darry, much appreciated will give the bios files a look into, Hopefully will now be able to solve my issues 😁
