Reply 14900 of 53205, by Rawrl
wrote:Going through stuff you find on old computers is half the fun. Over the years i've found: […]
wrote:Received the Thinkpad 380XD I had ordered a few days ago.. It was listed as "unknown condition, does not power up" so there was […]
Received the Thinkpad 380XD I had ordered a few days ago.. It was listed as "unknown condition, does not power up" so there was a bit of uneasiness of my part. But once I hooked it to a power supply, it fired right up. 😀 Gave me the errors 00161, 00163 and 00192 at boot. Entered setup and set the date, that got rid of the first 2 errors. The last one persisted (CMOS battery is dead) but it continued booting all the same. It has Windows 95 on it, and seems like someone's CVs and job applications from back in 2001. 😎 I'll replace the hard drive of course with a new one, and store the original one after I wipe it, don't want to be snooping through anyone's private papers. Even the main battery seems to be charging fine, I'll leave it plugged overnight and see how much juice it holds.
Now the CMOS battery I can't replace because I don't have the right size tonight. I have all sizes of batteries, but haven't had a use for a CR1220 so far so I don't have any. And no, a CR2032 or CR2025 won't fit because the 1220 is a narrower diameter (12mm vs 20mm). Guess that'll wait a day or two until I find a battery that fits.
Overall I'm very pleased. The laptop is almost pristine. Not a bad deal for $25 including shipping.
Oh yes, specs. PMMX 266, 48MB RAM, 4GB HDD, 12" TFT (800x600), CS4237B audio chip, FDD, CDROM, USB (1 port).
- IBM Confidential Source Code and information (most of it pertaining to 300 series mainframes)
- Various illegal things (basically anything pertaining to 90s era cybercrime ive seen at some point)
- Email logs between various engineers discussing some sort of audio file format
- all the customer data of a 1990s skating rink along with around a decade of logs from events
- a CD containing 3 years worth of patient documents and information from a local clinic
- A bunch of programs im pretty sure i own the last known, maintained, copies of.
- various other interesting stuff the general public can't seeI need to get around to archiving it. I was originally going to send most of it to Jason Scott (runs textfiles.com and the internet archives archive team) but he said most of it wouldn't be publically posted it. Sadly most of this data will degrade before I get access to any sort of mass floppy index'ing tool.
Obviously i wouldnt be publishing the skating rink data or clinic data unless theres snowden level stuff in it but the rest is fair game.Part of being in this hobby is: You have the potential to be Snowden 2.0
You also have the potential to be a massive creep. Personal communications, customer data, patient data? Most jurisdictions have pretty serious laws pertaining to exactly those things and the destruction thereof. Regardless of whether or not you release it, even archiving that stuff could land you in hot water if it ever gets discovered. Not to mention it's an incredibly skeevy thing to do.
Software and documentation are one thing, but anything with PII should be deleted, full stop.
