Old disk vs ssd
Reply 20 of 23, by 386SX
candle_86 wrote:
It was fixed with a bios update, just check to see if your board got the bios update, if it did not then don't use a live, use an Audigy
I've the latest bios and I've a C-media card, one of the only component not time correct cause I don't know about my Audigy capacitors status.
Reply 21 of 23, by candle_86
luckybob wrote:
I've really grown to like SSD drives. I try to put the quickest drive into any system possible.
Just be careful I got burned on some 8gb SSD's turns out the seller was using flash memory from a thumb drive soldered onto an SSD board with a USB to SATA chip inbetween with a USB 1.1 Controller was very disapointed
Reply 22 of 23, by Ampera
is your name drauga1?
Reply 23 of 23, by luckybob
No, but he has some pretty good ideas. I just wish he would buy a desk or table for his things.
