First post, by Smack2k
- Oldbie
Is there a trick to getting motherboards to recognize Compact Flash cards? Or is motherboard dependant? I have a Sockey 7 board that I want to use a 16 GB CF Card with. I have the CF Card installed in a CF-IDE Adapter card. When I boot up the PC and go into the BIOS it doesnt auto recognize the card, and when I go to choose what to use for a HDD, I am only presented with a few options, one of which looks to be 16 GB and is set to User, but I am not sure if that is right or not.
The board is a Freetech 586F60 Socket 7 Board if that helps at all...
Generally also looking for any tips on CF card use for a HDD setup on any motherboard.
