Reply 5120 of 31257, by Jade Falcon
Rank BANNED
BANNED
havli wrote:
Noticed small black Pentium pro sticker on one old Compaq PC at my workplace... so I loaded a copy of Speedsys on a floppy disk […]
Noticed small black Pentium pro sticker on one old Compaq PC at my workplace... so I loaded a copy of Speedsys on a floppy disk and it really is in there 🤣 Must have been quite expensive back in the day.
You should submit that on HWbot. Free gold 🤣
Reply 5121 of 31257, by brostenen
Not computer related.... For the first time, I saw "Once upon a time in the west".
I give it 5 out of 5. The brilliant move in this film, is that they do not tell anything before it happens.
And yes... Wonderfull camera work, wonderfull scenery and the bad guys are portraied as
a regulair dude and not as one of those hollywood stereotypes. Aka' psychopaths.
(it was the restored edition I saw)
For all western movie lovers... This is a golden oldie from Sergio leone.
Yes... The man who created "A fistfull of dollars" and other great westerns.
Reply 5122 of 31257, by PhilsComputerLab
Elsa GeForce 256 DDR got a new cooler 😀
YouTube, Facebook, Website
Reply 5123 of 31257, by oeuvre
http://i.imgur.com/3NPEZVU.jpg
Reply 5124 of 31257, by MrEWhite
Not very retro, but I ordered a black 103 key Model M from Unicomp with USB. Pretty excited to get it.
Reply 5125 of 31257, by kithylin
oeuvre wrote:
Interesting photoshopping.
Reply 5126 of 31257, by tikoellner
Today I got this caching VLB IDE controller. It's LCS-6941 rev. C. I decided to buy it as my VLB mobo (ASUS VL/I-486SVGO) does not seem to support LBA:
I found some firmware update here (http://manual.longshine.de/5_Old_Product_Driv … /1st-readme.txt) that mentiones LBA is supported by this card. Will give it a try.
Reply 5127 of 31257, by brostenen
I played some Super Mario World. (Mario Allstars edition)
Reply 5128 of 31257, by Nvm1
Today I removed three barrel batteries from the motherboards I bought in the big package as mentioned in Bought these (retro) hardware today
The first one went pretty good, it had hardly leaked and only had some crystals on one side of the battery.
Picture from (unknown) mobo:
20170211_222259_zps7sr7pndr.jpg.html
The ticking time bomb:
No damage to the surrounding parts:
Clean desoldered from the bottom:
Mobo cleared from the barrel bomb 🤣
No damage at all after the removal:
Patient number two, QD-U486DX with alot of damage to the surroundings of the shitty battery:
Complete mobo:
Close up of affected area.. lots of green goo:
Battery gone, didn't go too good. The solder hardly wanted to melt even at 400 degree Celsius after adding new solder 😠
Another close up of the damage:
Patient number three, again unknown mobo, already some damage surrounding the battery but it came of pretty good:
Full mobo after removal of battery:
Close up of area:
Another close up with better sight of the affected spots. I removed the Bios chip because there was some goo under it
All three mobo's are currently being cleaned with concentrated Lemon Juice which seems to clean most of it off.
Will post pictures of the after situation, hopefully with three fully functioning boards. If anybody has any info about the two unknown boards I would be happy. They don't have all settings silkscreened on them 😒
Reply 5129 of 31257, by keenmaster486
This is the only site I've found that works properly on Navigator 3. Can anyone point me to any other good ones?
World's foremost 486 enjoyer.
Reply 5130 of 31257, by kithylin
Unfortunately most 486 boards don't have any information on them. Some do.. but most don't. Your best bet is to get one to POST and then type the Bios ID string into google and you should be able to find more information. That's how I look up most of my motherboards.
Reply 5131 of 31257, by Tetrium
th99 and then browse through all the pics of all 486 boards. Should only be around 1700 of em 🤣
My retro rigs (old topic)
Report spammers here!
Reply 5132 of 31257, by Nvm1
If they post this is usually the easiest way. If they don't post then it will be a bit more tricky.
Reply 5133 of 31257, by Nvm1
Good way to lose two days of your life 🤣 I hope they post then the bios string might do the trick. If they don't post then it will be a very big puzzle..
Reply 5134 of 31257, by Tetrium
2 days??? With a good pic of the board I could do it in within half an hour (without taking any breaks and on a good day).
Have any pics?
Reply 5135 of 31257, by brostenen
I know the computer is not that old, yet it is going to be my daily driver from now on.
I changed the LCD panel in this lovely Thinkpad R61. Yeah....
The picture with the fresh panel, has not yet had the bezel re-attached. It is now.
The procedure is not really that complicated.
- Take off the bezel. (5 screws)
- Deattach the flat-cabels behind the screen and one plug located behind the pcb below the screen.
- Remove 4 screws from the rods that are connected to the hinges.
- Remove a fresh free'ed lcd panel.
- Do everything clockwise.
The first picture is the damage on the old panel, the second is the screen being tested.
The attachment Patiet-01.jpg is no longer available
The attachment Patiet-02.jpg is no longer available
Reply 5136 of 31257, by Tetrium
Duuuuude, I went through all pics on th99 and only found a couple boards that looked similar but then I noticed your board actually has the model number on the PCB.
Simple google search and I got this 486/P1/P2 and several goodies
It seems to be a Soyo 025D2 and its model number is on the yellow sticker near the top ISA slot 😵
Here's one that looked similar
http://www.uncreativelabs.de/th99/m/S-T/32316.htm
Your other mystery board also has a yellow sticker with the model number on it and it seems to be this one http://www.uncreativelabs.de/th99/m/S-T/31348.htm
Now you owe me a beer! 😈
edit: Lets make it a sixpack 😈 😈 😈 😈 😈 😈
edit2: Pack of Belgian special beer would be even better 🤣!
Reply 5137 of 31257, by lazibayer
I think it would be great helpful to create another indexing of th99's motherboards with respect to features, such as number of ISA slots, 30pin memory slots, etc.
Reply 5138 of 31257, by Tetrium
Should be doable using a similar table as already exists on Vogonswiki for the s370 boards (mostly centered around Tualatin, ISA, DDR and C3 support).
Reply 5139 of 31257, by CelGen
Managed to repair a power supply in a 70's HP computer that had been tormenting be for a year. One of two op-amps in the 5V regulation watchdog circuit had failed.
New chips are now on order. In the meantime I spent the rest of the morning building a replica of the Sony Playstation 2 VGA cable.
Now I just need to find the matching keyboard, mouse and monitor Sony sold (I'll pay good money for any of that, by the way) and I have a system ready to demo.
