Reply 5180 of 27716, by Tetrium
appiah4 wrote:
clueless1 wrote:
If it's a PODMMX, then it might support test register manipulation with Setmul. This would make it much more flexible for slowing down for older DOS games.
Just stick it back into the computer, power it on and run CHKCPU (assuming you haven't changed the motherboard jumpers that it was set to before you removed it). If so, hopefully you can remember how it was jumpered.
Changed the jumper for voltage from 3.3v to 2.8v only easy to change back.
Is a POD 166mmx better than a regular p166mmx? Why is the vcore so high? Is it basically an OCed lower Pentium?
A Pentium MMX Overdrive is basically a regular Pentium MMX with a voltage regulator and a fixed CPU multiplier. Both the boxed MMX chip and the overdrive came with a HSF attached to the CPU itself.
Pentium MMX Overdrive looks different from the bottom and the part number should tell you which one you have.
If the part number is BP80502166 it's actually a boxed Pentium 166 without MMX, but I can't tell from the pic as it isn't sharp enough.
My retro rigs (old topic)
Report spammers here!
Reply 5181 of 27716, by clueless1
Tetrium wrote:
A Pentium MMX Overdrive is basically a regular Pentium MMX with a voltage regulator and a fixed CPU multiplier. Both the boxed M […]
He did say it was jumpered to 3.3v, wouldn't that indicate it's an Overdrive?
Reply 5182 of 27716, by appiah4
Do these help?
http://image.bolterandchainsword.com/uploads/ … 1505_630856.jpg
http://image.bolterandchainsword.com/uploads/ … 1505_586811.jpg
Looks like a boxed pentium but I wonder why the board was set to 3.3v then...
Reply 5183 of 27716, by Jade Falcon
Rank BANNED
BANNED
Run of the mill 166mhz pent without mmx
http://www.cpu-world.com/CPUs/Pentium/Intel-P … BP80502166.html
Reply 5184 of 27716, by Tetrium
The s5/s7 Pentium classic CPUs were also 3.3v 😜
And the part number (which is hard to read so I can't be sure) indicates a regular Pentium (without MMX). Also the POD chips looked different from the bottom and this one doesn't seem to have an additional voltage regulator (though it may be the angle or something, doing this from top of my head here 😜).
Reply 5185 of 27716, by appiah4
Thanks for the ID its a boxed P166. The 166MMX stays on the board then. 😀
Reply 5186 of 27716, by clueless1
Yay! And thanks to Tetrium for setting me straight. 😉
Reply 5187 of 27716, by Tetrium
And thanks to someone else who noticed the sspec which I had overlooked myself (even though I should've known that 😜).
Reply 5188 of 27716, by creepingnet
Still checking on the parts I have coming in for the 486. Have the 128MB of RAM in there already...
- Diagnostic card is coming in today, don't need it here anymore, but I could definitely use it at work when it's not chasing problems on old x86 hardware at home.
- 486 DX4-100 with Write-Back is on it's way in today as well, toying with waiting for the heatsink to come in, or fabricating a better one using the Cyrix heatsink I have since the black heatsink won't be in until sometime next week at earliest.
- My 512KB Cache RAM finally made it to America, is in San Francisco the last time I looked, predicted to be here by Friday - which is a PERFECT day because if I choose to make my own CPU cooler (which I've done in the past) I can just get it done and won't have anything more to do regarding opening one of the vintage boxes until I order the Tandy's parts, and when I get a free moment to slip that RAMpAT card back in the 286.
Either way, I got all the ordering and budgeting done just in time to focus on the finishing touches for the Wife's birthday next week - if only I was so good at that as planning hardware upgrades.
~The Creeping Network~
Reply 5189 of 27716, by Skalabala
creepingnet wrote:
Still checking on the parts I have coming in for the 486. Have the 128MB of RAM in there already... […]
Bud do you have pictures on the forum of your 486?
I have a 486 motherboard with 4x72pin ram slots. Wonder how much ram it could take. Also have a 133mhz AMD cpu for it.
Reply 5190 of 27716, by creepingnet
Oh yeah, pictures, and update as I got home tonight and the DX4-100 CPU to replace the blown one came in, and much to my surprise, it came with a heatsink. I swapped the fan out on it though with the motherboard powered one (yes, my 486 board has a FAN power connector, which is the first time I've ever seen such a thing).
Installing the CPU was a bit of a PITA as it turns out there were REVISED jumper settings for the DX4-100 AMD CPU chips for the FIC 486-PVT system boards, and the second one was the correct one to \get this one working, had to use my Diagnostic card to figure out it was starting up to the point that POST takes over and then stopping, turned out I needed a SECOND 0 Ohm jumper shunt (in my case, some tight fitting staples bent into a U shape) and populate RN19 and RN17 - as soon as I did that, it fired right up, and it's been running ever since - about 2-3 hours now. I used Arctic Silver as thermal compound, seems to be doing it's job well, I had a big old syringe of that stuff and it's just sitting around doing nothing so might as well put it to use.
Checking Tracking, looks like the L2 Cache should be in tomorrow. All five 128Kx8 modules - making for a whooping 512K L2 Cache. That's a much simpler process, in this XT case, I just remove the thumbscrews from teh back (5), then take out a screw for the CD-RW and the IDE HDD tray, and remove those, and then I can press the chips in, pull 2 jumpers, and put them in the right spots for 512K L2 Cache, and I wont' be opening this thing for probably a very long time.
To answer the question on RAM, most 486 system boards top out at 64MB, but some of the later ones like mine (mine is a 1995 model board) goes up to 128MB, I also had an old Socket 3 IBM PC-330 100DX4 (6571-W5K) system years ago that could also do 128MB of RAM, though the most that ever had was 64MB of EDO ECC RAM. That IBM was the benchmark upon which all my 486 builds since were based because that thing ran darn near everything, Postal, Diablo, Quake, I used it as my main computer off/on from 2001-2005 and it never let me down till the system board went weird.
Reply 5191 of 27716, by oeuvre
dat AT101W, new in box.
    440.85 KiB
Reply 5192 of 27716, by TheAbandonwareGuy
Same keyboard I have. What's your opinion of it? Personally I like mine.
Reply 5193 of 27716, by torindkflt
Managed to find an MS-DOS MP3 player optimized specifically for 486 processors and listened to some music on my 486DX4-100 system...mostly 80s music. 🤣 I'd say a DX4-100 is right on the very edge of "just powerful enough" to be able to decode and play MP3s with no issues, as quick Google searches suggest other people who have tried this same thing weren't successful with a DX2-66...no word on a DX4-75 though (I don't have either one to test, and as fiddly as my current setup was to get working I'm hesitant to start poking around inside to simulate them just for experimentation purposes).
Reply 5194 of 27716, by oeuvre
Like it a lot so far, reminds me of my IBM model m
Reply 5195 of 27716, by Tommaso
Just out of curiosity what was the bit rate that those MP3's were encoded as? Most of mine are 320 kbits/sec so I am wondering if a computer like yours would be powerful enough to play then without glitches?
Tommaso
Reply 5196 of 27716, by torindkflt
Tommaso
Mostly 128-160kbps, but I do have one at 320kbps that it seems to have no trouble with, at least not in pure DOS mode. I imagine if I were to try to play any MP3s while Windows is running it would choke.
Reply 5197 of 27716, by appiah4
I remember playing 128kbit MP3s on my DX4-100 in Windows 95 using.. yes.. WinPlay3..
Reply 5198 of 27716, by torindkflt
I actually went back and tried playing MP3s while Windows was running, using the same DOS program (mpxplay) since I don't yet have an MP3 player for Windows on there. It actually worked better than I expected, but there were a few occasional skips and glitches that aren't present in pure DOS mode, but I'd say it's perhaps 90-95% normal. It also MUST be run in full-screen mode, as in windowed mode it is totally unplayable. I found the link to download the 486-optimized version of mpxplay here (bttr-software.de, which then links to SourceForge for the actual download).
Reply 5199 of 27716, by TheAbandonwareGuy
Whats the name of this MP3 Player?
