Reply 5500 of 27739, by xplus93
- Oldbie
wrote:Was playing around with an old iMac G3 333MHz, trying out some spare RAM chips I had. At one point I thought it's PSU had died as it point blank refused to power on - luckily however it was just the CPU/RAM card that wasn't reseated correctly after I swapped out the chips.
Wow those early G3 iMacs were horrible, a pain in the backside to upgrade and also extremely picky about the RAM chips they will accept. I put 2x 256MB PC100/133 SODIMM chips in and it only recognised half the RAM and was unstable. Think I'll have to settle for 192MB that I had before. Whilst it was running though I did give it a brief test playing Tomb Raider The Last Revelation whilst booted into Mac OS 9.1 and it ran ok but not really spectacular.
Also got around to installing a new OS on my Coppermine Pentium III 1.0GHz system, with Geforce 4 MX 440 AGP 8x. Funnily, the PC boasts stickers such as "designed for Windows 98" and yet I've found Windows XP seems to run much better so far - definitely something I'm going to have to look into (could possibly be because I have 768MB RAM installed, so will investigate further and actually I just remembered I hadn't tried installing the Via 4-in-1 drivers yet). For instance I used the PC version of Tomb Raider The Last Revelation as a test and despite being designed in the 9x era, I could only get it working somewhat okish in XP (has Graphics glitches that I've seen on several PCs), whereas 98 refused to go above 640x480 16-bit without crashing.
Could be that the newer drivers for the geforce 4 play better with XP than 9x. Could be the version of directx that's running?
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
