First post, by Gamuza
Hi again. I was wondering if you could set, say, an AMD K6-2 400 Mhz with a 100 Mhz bus speed to run at 66 Mhz bus speed? Could there be any problems, electrical or stability?
Also, could the reverse be done too? Set a processor with 66 Mhz bus speed to work at 100 Mhz?
Thanks in advance.
