Reply 16760 of 58808, by sp33dyS
badmojo wrote:
Whoa, me likes. Any good for DOS?
Only games with GrIP support 😒
Ryzen 5 5600X, Gigabyte X470 AORUS GAMING 5 WIFI, HyperX 32GB DDR4, MSI GF RTX 2070 GAMING Z
Reply 16761 of 58808, by TheAbandonwareGuy
chose007 wrote:
OK, just unpacked one :-D […]
havli wrote:
There is nothing special about this one. Maybe AGP X1950 XT could be called special... but 3650 definitely not. 🤣
OK, just unpacked one 😁
other cards not interesting so will put them back to schrott ... or not?
GF256 SDR
wheres RAM? here 😀
long time searching this one
6800 AGP
GF4 Ti4200 128MB
Why is it everybody on this forum can find a GeForce256 EXCEPT me?
Reply 16762 of 58808, by rnlf
I didn't buy it, but got it for free:
I don't have a PC with CGA or other composite video output yet, so my C64 had to be the test driver for this thing.
Reply 16763 of 58808, by Vegge
Picked up some free stuff today 😀
The attachment IMG_7850.JPG is no longer available
The attachment IMG_7851.JPG is no longer available
The attachment IMG_7852.JPG is no longer available
The attachment IMG_7853.JPG is no longer available
The boxes in the pictures comes with the original content. There was some more stuff but I only took pictures of the interesting stuff. 🤣
Tnt2 ultra agp
Matrix something agp
2 isa adaptec scsicards.
Some old modems.
Borland, lotus and other software.
Old computer magazines from the 80s from what I saw with a quick glance.
And a bunch of other stuff.
Edit: It's two AST rampage in box.
Reply 16764 of 58808, by stoof
@ Vegge:
Now that right there is a score.
What's inside the "image sharpener" box?
And uh, does this source of yours have any more cool stuff to part with? 😉
Reply 16765 of 58808, by Vegge
stoof wrote:
@ Vegge: […]
@ Vegge:
This:
The attachment IMG_7856.JPG is no longer available
He said he would give a shout if he found anything else 😎
Reply 16766 of 58808, by Cyrix200+
Nice!
Vegge wrote:
Picked up some free stuff today :happy: […]
Tnt2 ultra agp
Some old modems.
1982 to 2001
Reply 16767 of 58808, by appiah4
I'm the last person on the planet who can't seem to find a Model M keyboard in good shape and for cheap..
That is an incredible haul by the way, and I'm VERY jealous 😁
Reply 16768 of 58808, by Carlos S. M.
Ordered this from eBay
http://www.ebay.es/itm/262950254444
Just an usual P4 combo... untill i saw that ASUS Geforce 256 SDR
Reply 16769 of 58808, by yawetaG
yawetaG wrote:
Then, at the fleamarket in a nearby larger town, which usually sucks really badly (tons of absolute junk, sellers who think they're selling the crown jewels), I came across this:
Yamaha Portatone PSR-21, from 1986, in pretty good condition, including manuals, power supply and some music sheets. Unfortunately it lacks MIDI, but it does have a (very limited) synthesizer on board. That one cost me 30 Euros.
Popped the cover on the keyboard, and its heart is the Yamaha YM3812, the same OPL2 FM synth chip that was used in Adlibs and early Soundblaster cards! There's also the accompanying Yamaha Y3014 DAC, and a Yamaha chip XA90880 which yields zero Google results, so I guess it's a custom (ROM?) chip.
The keyboard has some neat features:
- 16 types of preset sounds, with a switchable synthesizer that has the choice of 4 different envelopes and 4 different tones (so when using the synthesizer, 4x4x16=256 different sounds are possible).
- Sustain, vibrato on/off, pitch adjustment, connector for an expression pedal, aux out (mono RCA jack unfortunately), can run off batteries or mains, integrated speakers, stereo headphone jack that disables integrated speakers (and can probably be used as a stereo line out).
- An integrated accompaniment drum machine with 16 presets (each with a maximum of 6 drum tones) and selectable beats per minute of 36 to 320 bpm. Each drum kit can be customized using a programmable sequencer to play a custom loop of notes. The drum machine can be automatically synched to anything you play, or be started/stopped by pressing a specific button. Also available is a fill in feature for drums only during playing pauses.
- A maximum polyphony of 9 (9 keys pressed at once). The polyphony can be exploited to produce some very synthy sounds.
- An integrated accompaniment bass(/electric bass/tuba/synth) option that, when enabled, splits the keyboard in two, letting you play two instruments at once, with the main instrument being piano/guitar/brass/synth. This also has an automatic mode that is similar to the drum machine except for the programmable pattern bit. When using the accompaniment feature polyphony drops to 4.
- What's really cool about the above, is that the accompaniments work additively, so it's possible to set up a drum sequence, have that play, then enable the bass accompaniment, press a few keys to set that up, change some settings of the bass accompaniment, press a few more keys, and the result is a fairly complex tune because the earlier bass accompaniment settings are kept in memory when the new ones are added!
Looks like this one will be a keeper, and I wonder whether it's possible to enable additional features with a little surgery...
Reply 16770 of 58808, by appiah4
Scored some new old stock stuff today.. Bought these two boxes for $25 each, shipped.
What's in those you say? AT cases I say.
Reply 16771 of 58808, by tikoellner
Today's small haul.
In order of appearance:
1) CH Products MACH II joystick.
I got it locally almost for free. Like new condition. I already have one similar - CH Products Mach I+ model, but this one is a lot better in terms of precision mainly due to the shape of the grip. I generally like those joysticks very much for their looks and EXCELLENT build quality. They are made by the company making industrial grade stuff and you can really tell by the way these joysticks feel
2) AdPlus Sound Galaxy NX.
Thank you @Batyra. The card seems to be an early revision of AZTECH Sound Galaxy NX. On the PCB it says "AdPlus", which dose not correspond with the sticker on the back of the PCB. I'm not the biggest AZTECH fan. Their products just don't have this magic and I mostly think of them as being cheap OEM stuff (which is not just), but I just can't resist buying any decent 8-bit ISA sound card out there. Seems like this card is pretty rare as well! (Batyra surely knew this while negotiating 😉)
Reply 16772 of 58808, by Brickpad
Picked this up the other day for $12US and free shipping.
Reply 16773 of 58808, by dexvx
If that is a GeForce 256, looks like DDR version to me. Asus V6600 (GeForce 256 SDR) had 8 memory banks instead of 4 on front side.
Reply 16774 of 58808, by Arctic
I will try to look for some decent ISA sound cards at the next local flea market.
Do any of you guys know a site where you can read about the different GUS models?
Reply 16775 of 58808, by BLockOUT
i paid
6 dollars for the m919 coast module
and i still can´t belive it
Reply 16776 of 58808, by fitzpatr
Carlos S. M. wrote:
Tetrium wrote:
I noticed this as well. Also the ASUS TNT2 looks more to be a TNT2 M64 […]
fitzpatr wrote:
Included are a voodoo3 3000 (D?) AGPV3800/32M Riva TNT2
Arctic wrote:
@fitzpatr
That seems to be a Voodoo 3 2000 (small passive heatsink)
Yeah, the ASUS V3800 is a TNT2, but the V3800M is an TNT2 M64
Sadly, I didn't have data (traveling in the USA), nor time to really research. I definitely missed that M in the model though...🤣. Well, for $20 I got a Geforce 256 SDR, Voodoo3 2000, RIVA TNT2 M64, and a somewhat junky sound card. I'm not complaining.
On another note, I have finally returned home, and my father-in-law has a massive amount of computer and other electronic parts. I literally walked in their door and saw an Asus P5B and MSI 6163 Pro sitting there. I've already gathered 286, 386, and 486 boards for testing and sale/use. I'll post pictures soon.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 16777 of 58808, by kixs
BLockOUT wrote:
i paid
Last year I purely by coincidence found a few of these M919 modules on one Brazilian auction site. Fellow vogoner from Brazil agreed to buy them and send them over to me. After he bought them and a few exchanged messages he didn't respond any more. Needless to say I never got them...
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 16778 of 58808, by luisile
Todays was a good day. One good friend finaly give me a working 6800 ultra! And the price was - for free! So for my athlon xp i have finaly a gpu. Now i only need a good power supply.
Reply 16779 of 58808, by Dreamer_of_the_past
And a better cooler with fresh thermal paste probably too.
