Reply 16860 of 53082, by cyclone3d
My lot of 13 PCI sound cards came in. It turned out to be 14 cards.
In the lot were:
2x Yamaha YMF-724
1x Vortex 2
1x Vortex 1
1x ForteMedia FM801
1x S3 Sonic Vibes
3x Advance Logic ALS4000
And some Creative cards
1x CT5806
1x CT5801
2x CT5803
1x CT4810
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 16862 of 53082, by ODwilly
Cyrix200+ wrote:
man-x86 wrote:
Cyrix200+ wrote:
<snip>
I used the same motherboard for some tests, and it has everything one needs for tinkering with an old machine.
It is also possible to easily modify the BIOS (I got the same motherboard with a NEC BIOS, upgraded to a MSI bios, Coreboot and a tuned MSI bios at the end). Upgrading the BIOS makes it a great motherboard, although keeping the original bios on a separate chip might be helpful against Murphy's law.
Thanks, I might try that! This board is quite unstable unfortunately, and the onboard video flickers (on two LCD screens I tried it on). I put it aside right next to the recycle bin, but maybe I will need to give it another chance 😀
Just a thought, but perhaps the onboard Rage is defective and that was why it had that pic sis card in it. Kind of like when an onboard nic goes out and you see a pci one in a machine.
Reply 16863 of 53082, by dexvx
Socket 4 Pentium Overdrive. Now I need help finding a Socket 4 motherboard (or if anyone lives in the PDX area that would let me put this in their socket 4 system).
Reply 16864 of 53082, by man-x86
You may wanna check for bad solder joints or bad capacitors, I had plenty of boards from that era with such issues, but depending on the usefulness of the board, it's probably not worth fixing (unfortunately).
Reply 16866 of 53082, by tabm0de
Going to get this bad boy tomorrow:
VIKTOR VPC IIe
I hope it was worth $86
    4.72 MiB
naa, nothing yet...
Reply 16867 of 53082, by Skyscraper
VIKTOR VPC IIe
The screen alone is worth at least as much if it works. 😀
Reply 16868 of 53082, by Carlos S. M.
Got 3 motherboards locally for 15 €, were sold as untested, but i tested and all 3 mobos works, two of them needs cap replacement though
Left: QDI Advance 10B/F with Pentium 3 1 GHz
Middle: Gigabyte GA-5AX rev 5.2 with AMD K6-2 500
Right: GIgabyte GA-6VXE7+ with Pentium 3 800EB
    2.16 MiB
Reply 16869 of 53082, by Cyrix200+
Nice, I'm still looking for a 5AX. Those are nice boards!
Carlos S. M. wrote:
Got 3 motherboards locally for 15 €, were sold as untested, but i tested and all 3 mobos works, two of them needs cap replacemen […]
1982 to 2001
Reply 16870 of 53082, by Godlike
Gigabyte GA-5AX, great piece of hardware. Thanks for remind me to recap my CUSL2-C
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Reply 16873 of 53082, by Gamecollector
appiah4 wrote:
What is so special about the GA-5AX?
One of best SS7 ATX motherboards.
Reply 16874 of 53082, by luckybob
I would argue the Asus P5A & P5A-B are better. Honestly they are practically equal.
Reply 16875 of 53082, by brostenen
Depends on the revision. Generally speaking, P5A and GA-5AX are both in the top 5. Maby even in the top 3. I have both P5A rev 1.06 and GA-5AX rev 4.something (4.1?).
I cant tell the difference when running a K6-II-500 or K6-III-400. Never had a plus model to test with.
Reply 16876 of 53082, by Skyscraper
I just bought a new in box Asus PC-DL dual Socket 604 Xeon i875P motherboard.
The price was reasonable considering that used boards are costing 200 euros and up on Ebay because this is considered to be the top motherboard for running dual Gallatin Xeons... So yea only an arm, a leg, a kidney and part of the liver... I also got a mail fordwarder in the UK and bought a couple of 3.2 GHz 2MB L3 Gallatins to see how they compare with my 3.2 GHz 1MB and 3.0 GHz 4MB ones. Other than a few much cheaper motherboards in my watch list, Xeon cooling and perhaps a couple of cheap CPUs I'm done with spending money on retro hardware for the next half a year or so.
The Asus PC-DL (picture from the Internet).
450.25 KiB
Reply 16877 of 53082, by PcBytes
Seems I wasn't so lucky today.
I tried hard to search for a better GPU than my old FX5200 64MB (that ABiT Siluro I was talking about having 64MB RAM) and I somehow ended with something worse than that - a Radeon 9600SE 128MB V/D/VO. Not only it's 64-bit - I can't even BIOS mod it (9600s and 9550s were supposedly able to be BIOS-modded into 9700s or 9800s - something around that) and to top that, it can't display a color image over my home-made S-Video cable. ( out of PS/2 keyboard cable - methinks one of the main signals - either Luma or Chroma - is on the unused pins that I snapped off - in which case I'll try and find a way to build another one from a old HP cable - it has more wires which may mean it is fully wired for each PS/2 signal, which in turn might provide me a full colour image regardless of what GPU I use).
And the $64 question is: is the 128MB 9600SE in any way better than the 64MB FX5200, performance wise?
Reply 16878 of 53082, by tabm0de
Got it home today and it works great 😀
But damn it was slower the expected haha
    2.7 MiB
    2.34 MiB
    2.97 MiB
    1.8 MiB
naa, nothing yet...
Reply 16879 of 53082, by brostenen
A quick google search, indecates that the 9600se is a lot faster than the fx5200.
I could be wrong though.
