bjwil1991 wrote:xplus93 wrote:
Are you getting any mechanical indication of the drive attempting to read the disk? If you get an instant error returned then it's most likely a driver or configuration issue. If you hear it trying to focus lock clean the lens and lube the rails.
It is attempting to read the disk when the laser is about 1cm away from the spindle, but the drive spins up, then down, and the head does move. I tried cleaning the lens, and the rails are a PITA to get to. And what should I use to lubricate the rails?
Depending on the type lithium grease or sewing machine oil, or in rare cases they are meant to be unlubricated and you just need to clean off the dust. That's usually very high end audio transports though. If the old stuff looks thick and paste like then use lithium grease, if not then use a small amount of sewing machine oil. Using a wooden toothpick to apply it helps make sure you dont use too much.
Also when cleaning the lens, generous amounts of high percentage rubbing alcohol work best because you can dissolve the dirt in it and it gets absorbed by the q-tip and the remainder evaporates away from the lens instead of having to wipe it dry and leave smudges.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
