Reply 17160 of 53191, by Carlos S. M.
wrote:wrote:wrote:That's odd. My cards have thermal pads between the large black radiator and the video memory. They also had a gray thermal compound (witch I replaced). I'll see if I can find some pics.
This was mine when I took it apart. Although bear in mind I do have the "Extreme" card and I believe yours are the XXX cards. Perhaps with the XXX they included ram pads and better TIM. It's a possibility.
Mine went something like this: stock "stick it in the machine and nothing else" = 85c - 88c core temps, replacing TIM with grey arctic silver 5 = 65c-72c temps. Mounting a 60mm fan on the heatsink on the back of it, connecting it to the onboard fan header, and putting in a custom fan curve in the computer via afterburner for 30% fan @ 55c = constant gaming temps of 50c-55c usually, even in demanding titles. Didn't get a lot of time testing I'm happy. A little work and I've almost halved the temps on it. 55c is -tons- better. Hope it lasts now. I haven't investigated if I can get it working with win98 yet, still playing with it in XP on my P4 computer. And I may later investigate trying to modify it's bios to see if I can program in a custom fan curve. By default it pushes this fan to 100% @ 55c and it's noisy. I also disassembled a broken quadro card, and sacrificed another one of my other quadro cards I don't care for (paid $3 for it) and now have full thermal pads on all the ram chips as well to contact to this heatsink.
They don't work on win98 🙁 - no drivers...
I think he mean using the custom/modded drivers, i know there are some custom drivers for Windows 98 SE and the Geforce 7 cards
