Reply 17360 of 58849, by dexvx
I highly doubt my seller would do that. He said something along the lines of if it doesn't POST he'd refund minus shipping. Went over the jumper settings, and nothing wrong. Only wrong configuration was the EDO instead of FPM. But that shouldn't melt the VRM. Another possible issue maybe the ATX PSU + ATX -> AT converter (seller said ATX PSU having a -5V wouldn't affect it). So no clue! Sad 🙁
For consolation, this arrived today. Athlon (Thunderbird) 1GHz Slot-A. I believe it is the fastest Slot-A processor. Sniped off eBay for pretty cheap, and it just happened to have a HP Asus K7M with it. At least they POST (same PSU as my 486 attempt, minus ATX -> AT converter).
Reply 17361 of 58849, by Cyrix200+
Good to hear that is working. That is is high on my list : ) You have some guts though using that same PSU...
dexvx wrote:
I highly doubt my seller would do that. He said something along the lines of if it doesn't POST he'd refund minus shipping. Went […]
1982 to 2001
Reply 17362 of 58849, by Deksor
Bought this in at a garage sale :
The attachment IMG_20170611_225011.jpg is no longer available
Some odd 286 ISA board (there was also an 8088 one)
The attachment IMG_20170611_224952.jpg is no longer available
Coming with something to connect them with other cards I guess. I didn't manage to make it work unfortunately
The attachment IMG_20170611_225019.jpg is no longer available
What looks to be an RTC board. Sweet ! I needed that for my 8088
The attachment IMG_20170611_225030.jpg is no longer available
A 486, (with other few parts) that works but behaves oddly : I can't plug any VLB video card or the computer won't POST (I tried to add waitstates but had no luck) the board doesn't post either if a keyboard is not detected. Some (rare) times, it doesn't want to POST at all and other times it may crash(maybe cache related issue, I tested many rams and it didn't fix anything)
So yeah all of this are neat little thing (I didn't show all of what I got, the rest is "boring" 8 bit ISA stuff ^^) but for the 486 board, I don't really know why it refuses all of the VLB video cards I tried to put in (IO vlb cards seemed to work)
Reply 17363 of 58849, by xplus93
Deksor wrote:
Bought this in at a garage sale : […]
I would assume you power it through the backplane in the second pic. Is that a keyboard connector on the end?
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 17364 of 58849, by Deksor
Looks like it is. I don't know if it's communicating in XT or AT mode. However there are 4 leds on the board but they didn't do anything when I powered the board 🙁. The POST card didn't output anything either and there was no video either. Finding informations for these might be difficult too 😒
At least I guess that if I find a board with dead "Chips" chips, I will be able to repair it easily
Reply 17365 of 58849, by mv_cz
Kreshna Aryaguna Nurzaman wrote:
mv_cz wrote:
Finally bought (sort of.. :blush: ) a 3dfx card on a local discussion board, the seller didn't want anything for it, only a bar […]
Finally bought (sort of.. 😊 ) a 3dfx card on a local discussion board, the seller didn't want anything for it, only a bar of chocolate, so I bought him two large ones 😁 Got a Creative 3D Blaster Banshee PCI (CT6760) with original drivers CD and with it came also SB Live! CT4670 card (although I have a modern revision CT4830 with digital out, it will come in handy).
I've only had a Voodoo1 card back then, friend of mine had similar creative banshee card, but it was an AGP version with SGRAM and paired with celeron333 it was quite capable system. Today also came new old stock AMD K6-III+ 400 MHz which I've ordered on ebay for 20 euros. So I have some hardware to complement my socket7 systems.
Nice. So you've just completed your entire system in a single buy, have you? Banshee is a quite capable card; in single-textured games it's faster than a Voodoo2. The 2D image quality doesn't disappoint either.
Well actually I'm not sure 😁 I planned to keep both socket7 and supersocket7 systems. The first mainly with P233MMX for dos with PCI graphics (where should banshee go) and the ss7 setup with K6-3+ and AGP graphics for 98SE and slightly modern games. But I don't have proper AGP card at the moment, either they are too slow (TNT2 M64, GF2MX - actually this card seems most appropriate now) or too fast and modern (GF4Ti4800, FX5900) for ss7 system and none of them are 3dfx cards of course.
With mobile K6's ability to clock itself down on the fly I feel like the first setup being more or less redundant, but if i put pci banshee in ss7 then it will become bottleneck 😢
dondiego wrote:
AKA trident blade xp5, also had only dx 8.1 support.
The XP5 was sold under the "XGI" brand if my memory serves well, but it is more or less rebranded Trident XP4 card. Because in my Toshiba centrino laptop I have XP4m32 card and I have managed to modify XP5 graphics driver from dell to work on my XP4 card. I needed to try some newer revision of drivers for my chip, because it has somewhat slow scrolling in modern windows apps in WinXP. And since XP4 drivers I have are already the most recent, I used the XP5 and they work.
After all the XP4 is not that bad for time of it's release. Sure my laptop could have obligatory Intels's extreme graphics in form of 855GM chipset, but trident is faster, power efficient and brings directx 8.1 support. In 3Dmark2001SE performance is good and the card was clearly optimized to run it well, It reaches nearly the score similar to Mobility Radeon9000. In games it is not that good, fps drops here and there, but the picture quality is OK, I had never problem with trident cards regarding to picture quality (same story was with Trident Cyberblade e4-128 card I had in laptop too).
So maybe VolariV3 = XP5 = XP4 which gives me idea to try volari drivers 😊 Shame those XP4/5 cards are not supported in Windows Vista/7 😢
Reply 17366 of 58849, by appiah4
Not hardware but this made me very happy when it came in the mail (although the box was crushed due to poor packaging, grr..)
Reply 17367 of 58849, by Carlos S. M.
I ordered an ASUS A7S333 for 17 € shipped, one of the few SiS 745 Socket 462 motherboards which came on the market
Reply 17368 of 58849, by kixs
appiah4 wrote:
Not hardware but this made me very happy when it came in the mail (although the box was crushed due to poor packaging, grr..) […]
I wish they would fill the box with some crumpled paper to save the box from crushing. Most don't even if I ask them to 🙁
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 17369 of 58849, by Kreshna Aryaguna Nurzaman
A7S333 or A7V333? Never heard about the former, but the latter is the fastest mobo with AGP 2x support --an ideal mobo for those who wish to run their Voodoo5 5500 AGP with the fastest CPU possible.
Kreshna Aryaguna Nurzaman.
Reply 17370 of 58849, by Carlos S. M.
is actually A7S333 which is based on the SiS 745, the ASUS A7V333 uses the VIA KT333 rev CD
A manual for the ASUS A7S333 exists on the internet: http://www.tekwind.co.jp/backup_uc/support/do … /a/a7s333_e.pdf
About KT333 motherboards, i have an MSI KT3 Ultra2 (CE) with the upgraded KT333 CE revision and FSB166 support while keeping the AGP 2x support, the BIOS has official support for Bartons
Reply 17371 of 58849, by mv_cz
and it has 4 mounting holes for installing a serious cooler, woo-hoo 😎
Reply 17372 of 58849, by Arctic
Revision 2.00 of the A7V333 has official Barton support. 😎
Reply 17373 of 58849, by dexvx
Does A7V333 Rev 2.0 have the universal AGP? I would assume so since Arctic seems to be running a 3.3V Voodoo5 5500 AGP off it. I always thought A7V333 Rev 2.0 was 1.5V only.
Reply 17374 of 58849, by chose007
@dexvx: nice Athlon 1GHz 😁
I got one too, so can finish collecting slot A platform.
and other schrott
some additional medical 3D cards
CHIPS ISA + Savage 2000
3dfx
fastest DDR2
and DDR1 550
Reply 17375 of 58849, by Gamecollector
chose007 wrote:
http://i810.photobucket.com/albums/zz23/prospekty7/hwnet8/DSCF5671_resize_zpsbgmwpjxx.jpg […]
Drivers cd version 3.x?
Reply 17376 of 58849, by chose007
Its 1.00
Reply 17377 of 58849, by dexvx
Nice, unfortunately, since mine was HP OEM, it only has a somewhat large heatsink. Hard to install a fan because it will get very close to the memory sockets.
I think the classic Athlon (Orion core) 1GHz is much rarer. I was at a recycler and saw an Athlon 700 MHz (Pluto, fastest of that core). May pick it up if it's still there next time.
Reply 17378 of 58849, by TheAbandonwareGuy
The last time I made some very professional looking message to seller saying how I chose there listing based on condition (which I usually do, as better maintained ones are usually the games that turn out to have working floppys) and that if it arrived in good condition they could expect both a positive review and further business from me.
They sent it in a box with foam sheets as padding, the box wrapped in bubble wrap, inside another box, surrounded by packing peanuts, inside yet another box. All 3 boxes of the double wall variety. I mean what I had bought was a slim big box copy of Star Trek 25th Anniversary. There packing literally trippled the size of the package. Impressive, that box was ready to survive the apocalypse.
BTW you have to keep in mind alot of large sellers already have there items packaged minus a shipping label. It's sad to say, but it might not be practical for them to spend time repackaging it and wasting packing materials. The profit margins on these things aren't always huge. Gotta play the devil's advocate and remind everyone there humans too, gotta make a living the same as us. Plus, no matter how something is shipped sometimes there will be damage.
Reply 17379 of 58849, by kithylin
I've been searching for a 1Ghz Slot-A Athlon Thunderbird (with the full speed cache) for many years now.. I haven't actually seen one actually for sale anywhere since right about when they came out new originally and the 3-5 years after that then they sort of all disappeared. Well rather, I did see one on ebay once for $600.. but that doesn't really count.
