Reply 17560 of 58793, by LHN91
wrote:wrote:Pardon the awful cellphone picture - among a few other things I picked up this Socket 3 motherboard today. […]
Already removed the Barrel battery, but there's two issues so far - it doesn't seem to want to POST and also there is some minor corrosion from the battery. It doesn't appear to have damaged any traces but I'll need to get that neutralized and cleaned soon.
That said, when power is applied the CPU warms up and other things on the board get power (the LED outputs) so I have hope for the board.... I'm just a bit out of my element with pre-Socket 7 boards.
Definitely could use suggestions on cleaning up the corrosion, and on identifying and troubleshooting the board. It seems like a really good late 486 board, with VLB, PCI, external battery connector and support for AMD/Cyrix processors and both 3.3 and 5v processors.
Check the memory to see if they match, or replace them with SIMM-72 memory. In most cases, the memory could be mismatched with the SIMM-30 (size and speed must match), or just dusty.
The RAM was already on the board when I got it - it was already in an assembled system and looked to have been mostly untouched before I tested and then disassembled it. I'll see if I have any other SIMMs to try.
