Reply 18740 of 58398, by TheAbandonwareGuy
appiah4 wrote:
I found an HP Vectra VEi 8 with unknown configuration; apparently a P3 Slot 1 with integrated Matrox G200 and Crystal CS4280, for 15 bucks.. Not sure if I will get it though as I have a system that covers the era. Just curious şf there is anything special about their builds or cases..
Integrated G200 would make it nice for 2D games like baldurs gate assuming it has the usual G200 through the roof signal quality.
Reply 18741 of 58398, by The Serpent Rider
cyclone3d wrote:
Thinking the current BX based motherboard I have is faulty as I was not able to get it to POST.
ASUS BX boards are practically bulletproof.
Reply 18742 of 58398, by cj_reha
More thrift store stuff.
-Beige PC tower w/ Intel 845 motherboard, socket 478 Celeron 2.0ghz, 512MB DDR266, onboard video/sound, 80 GB WD Caviar w/ password locked install of XP Home. A few bulging caps but it works fine (so far.) - $10
-Boxed HDD caddy - 75 cents
-Mouse Systems serial mouse - 99 cents
-USB 3.5" floppy drive. - 99 cents
And some stuff from an electronics store.
-40 ish caps for recapping an A-Trend slot 1 board I have.
-Arctic Silver thermal paste
-Spool of solder braid.
The thrift store has maybe 5 or 6 gray Dells (specifically like 4 Dimension 3000s) and a couple HP Pentium4 HT towers, $10 each. Is it worth it? Checked inside one of the P4HT towers and they still have the hard drives. (may be wiped, they were sold as untested.)
Reply 18743 of 58398, by TheAbandonwareGuy
cj_reha wrote:
More thrift store stuff. […]
The Dells that have AGP yes. If there non-AGP models I would say grab one incase you ever need a burner system you wouldn't mind losing. Thats what I use mine for. The HP's would probably make good early PCIe gaming systems.
Reply 18744 of 58398, by cj_reha
Didn't check inside the Dimensions, but if they're anything like my dad's Dimension 2400 work PC, they're PCI only. I'll probably grab one next time if someone didn't steal the CPU, RAM, HDD, and graphics card like someone did with a lone Dell Optiplex in the middle of the Dimensions.
Reply 18745 of 58398, by shamino
It's more likely that somebody just deleted the partitions or reformatted them. Not many people seem to know how to actually wipe a drive, and that leads to all the overkill paranoia out there about data security.
If you have the appropriate type of install CD then you can install XP on those machines using the license which is embedded in their BIOS. A retail XP disc won't recognize that though.
I don't know if all Dimension 3000s are the same, but the one I bought a few years ago had an 800FSB Prescott HT mPGA478 board but no AGP. The nicest thing about it is the case, which has a nice simple side panel that easily comes off. It's not one of those maddening clamshells Dell was so fond of.
I believe the 3000's case is physically microATX and will fit standard microATX boards, but I haven't tried swapping. It still uses Dell's front panel ribbon connector though. I suppose there could be adapters to break that out into conventional connections.
The HPs might be better.
Reply 18746 of 58398, by TheAbandonwareGuy
How could someone basically strip a PC without being noticed?
Reply 18747 of 58398, by cj_reha
This thrift store isn't in the greatest of neighborhoods, plus the electronics section is in the way back of the store. Also many don't require tools to open. I opened the Pentium 4 HT tower by unscrewing the thumbscrews with my fingers.
Reply 18748 of 58398, by probnot
Picked up what looked old enough to be a socket 7 atx system, but the insides were upgraded at some point. Oh well, still some stuff I can use. I kinda like the look of the case.
oVewwjZm.jpgMwlcPUKm.jpg?1
Pentium III 800E
Asus P3V 4X
896MB Ram (4 sticks, not sure the sizes yet)
Matrox Mystique PCI (4MB)
Aureal Vortex 8820
Seagate 8GB HDD
WD 15GB HDD
It was being sold as dead, but just needed a different PSU. Booted into a painfully slow Windows XP install (that appears to have been used as recently as 2011)
Reply 18749 of 58398, by liqmat
So do I. The internals aren't too bad. I really like the cheesy case badge. I am doing a Win98SE build right now with similar specs.
Reply 18750 of 58398, by cj_reha
probnot wrote:
Picked up what looked old enough to be a socket 7 atx system, but the insides were upgraded at some point. Oh well, still some s […]
Pentium III 800E
Asus P3V 4X
Aureal Vortex 8820
Seagate 8GB HDD
WD 15GB HDD
I want a Computer King 🤣
Reply 18752 of 58398, by brostenen
This... Tested and fully recapped with long lasting tantalum capacitors. RF modulator removed. Sellers picture.
A bit expensive, yet these things do not come cheap anymore. 🙁
The attachment a600-mobo.jpg is no longer available
Reply 18754 of 58398, by brostenen
Yeah.... The old board was giving me too many issues, even after a recap. A full repair of the old, might cost me twice as much, compared to what I payed for this one. The old board was working fine after a recap, yet after a couple of days, the issues went from perfect to far worse than before a recap. And it has even begun to get that bad-cap fishy smell now. Symptoms like blueish colored screen, undtable loading from floppy drive, over 30 seconds on boot before software will load from a media and all the leds have begun to blink now. The same day the problems began to come back, it just started with the floppy led being active all the time. Hmmm... Well.... After a thread at amiga.org, I have come to the conclusiuon that the old board will cost me more to fully restore, than what I have payed for the replacement board.
As for the old board... Well... If it can be restored, then I guess another person have to buy it from me, and give it a go.
I am not throwing more money after that board, so if someone think it can be done, then I will sell it for really cheap at amibay.
And if it can not be done, then I might just throw it out. After all... There comes a time, were things is not repairable anymore.
EDIT:
I have been in contact with the seller, and there should be caps soldered on the actual board it self.
So I guess that eighter the caps used are not actual orange or the photo has been taken before them being soldered in.
Eighter way... There should be caps at the spots. 😀
Reply 18756 of 58398, by brostenen
Deksor wrote:
Even though the board would be completely busted, I'm pretty sure a repairer could take the custom chips off
True.... Think it will be sold as a donor-board then.
Reply 18757 of 58398, by xplus93
Pentium III 800E
Asus P3V 4X
Aureal Vortex 8820
Seagate 8GB HDD
WD 15GB HDD
Kinda neat. Looks like a SS7 PC and X68000 combined.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 18759 of 58398, by probnot
What I find interesting is that it has a Turbo LED and a cut-out below the power button for a Turbo button...but it's an ATX form factor. This must have been a really early ATX design, I don't remember seeing even early Pentiums having Turbo buttons.
