Reply 18960 of 58840, by Nvm1
Munx wrote:
lazibayer wrote:
Nvm1 wrote:
Will those two be enough? :lol: […]
Will those two be enough? 🤣
On the top it still has the thermal pad from how it was mounted in the notebook it came out so nothing to see there so far.
Interesting... Why would a laptop manufacturer convert a MMC1 processor into socket 7, instead of having MMC1 on the laptop side?
Before Tillamooks laptops just had regular desktop sockets for Pentiums, so I'm guessing it's so manufacturers wouldn't have to re-do or modify their PCBs
As far as I understand now it is socket 7 but with some alterations, hence the problems with getting the cache working and if I am correct I found somewhere on a german forum info that voltages would be different too. However there must be a way to get this working in atleast some desktop motherboards.
Reply 18961 of 58840, by brostenen
peklop wrote:
What is this 486 CPU? I have same with same heatsink but cant identify without removing.
appiah4 wrote:
Considering buying some of the below, would vogons help me with deciding which ones are worth having? Also is the motherboard/cpu/ram set worth $25?
https://www.vogons.org/download/file.php?id=38010&mode=view […]
I have one that has the exact same heatsink. It was from an IBM machine, and it is an Dx2-66 with WT cache.
On mine, there are i66 written/scratched/etched into the gold plate.
Though I have another heatsink-less 66'er that are also WT, yet the gold plate is smaller.
Reply 18962 of 58840, by brostenen
BSA Starfire wrote:
Bought this the other week, it's a Acorn BBC micro Model B, 32K, 2MHz 6502 CPU. It has a MMC SD that acts as a 1 GB hard disk with a load of games(over 420) installed. This is an issue 3 motherboard from early 1983. The BBC computer was built around a early initiative to make the UK computer literate, it's original cost was £399 in 1982, equivalent to £1200 today. It was the machine installed in most schools here in the UK during the 1980's, eventually selling over 1.5 Million units. Acorn the designer and manufacturer of the BBC micro then went on to develop the ARM CPU in 1985, the backbone of today's computing world.
What a wonderfull little machine you got there. We had something like that in Denmark, though it was build for schools only.
They did not produce seperate models for schools and homes, as Acorn did in the UK.
The ones in Denmark, was a seperate computer, and seperate disk drive, that could be shared by up to four machines.
It was powered by an 80186 CPU and ran eighter CPM or Basic. (as far as I remember) everything, even the keyboard was all metal.
Reply 18963 of 58840, by PTherapist
Bought a few days back, received today.
286 Motherboard with 12MHz CPU, 1MB RAM. No idea of the make/model of this, I just saw the spec and it was ideal for the system I wanted to build - namely a lower end 286 purely for 80s-early 90s DOS games and programs, perhaps with GEM as a GUI.
Reply 18964 of 58840, by hard1k
Coin cell battery on a 286? Is this a mod or an original feature?
Also beware of that EPROM with the glass window - it might have been already erased by accident.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 18965 of 58840, by cj_reha
Few weeks back was talking with an uncle of mine and he mentioned having worked on old 386's and 486's and early Pentiums back in the day. A few hours' conversation later he agreed to look in his closet and drawer for old Pc stuff he may have kept. Package came today and it looks like he found some stuff!
https://imgur.com/a/EWCnH - Imgur album
Highlights include an ATi All In Wonder PRO PCI graphics card with RAM upgrade module and manual, and a socket 3 AMD 5x86-133MHz!
Reply 18966 of 58840, by PTherapist
No idea about the battery, I wondered if it was a mod also.
Glad you mentioned the EPROM, they were both covered with a sticker and it had fallen off before I moved the motherboard to take that photo. Just tested the board now and thankfully its fine. I'll make sure they stay covered up.
Reply 18967 of 58840, by Jade Falcon
Rank BANNED
BANNED
Not quite new or retro.
But I got really lucky. I made an offer on a Asus ROG laptop of 60$-shipped and won! The laptop is in really good shape too.
It has a 2ghz c2d (will upgrade) a gtx260m 1gb and 4gb of ram with a 320gb hard drive and Blu-ray drive. Supports dual hdds and has a mxm video card slot. Sadly the mxm slot is upside down so finding a newer card with a lower TPD will not be easy. I may just remove it all together.
The battery is bad, but for what I'll be using it for that no biggy. I'll mostly use it to replace the old circa 2003 laptop I been using to work on cars. IE a garage computer.
Reply 18968 of 58840, by lazibayer
I have a 266MHz tilly and it works (without L2) on GA-5SMM. @meijor has done a lot of work and found L2 cache working on a P5SJ-A. As for voltages, the 1.8-2.0V Vcore is easier to reach than 2.5V VIO. It works with 3.3V VIO on my board but I only use it for testing purposes.
Officially socket 7 version only goes up to 266MHz, so the conversion is either done by the laptop manufacturer or by Intel thru special order. Either way, I guess, is cheaper than redesigning the laptop.
Reply 18969 of 58840, by Gamecollector
1.9 V core and 2.5 V I/O.
Reply 18970 of 58840, by Predator99
Primax AltraSound Soundstorm Wave and GUS PnP. GUS sold as defective but working 😎 Courisously only no sound when using ROM samples. When switching to RAM it works perfectly. Dont know the reason yet.
The attachment IMG_7883r.jpg is no longer available
From another 6 kg lot I got very cheap. Most interesting parts
The attachment IMG_7878r.jpg is no longer available
The attachment IMG_7877r.jpg is no longer available
- some sort of ASUS PCI SCSI/Soundcard with a Vibra Chip
- CT1350B
- Several AZTECH Cards
- Mozart
- Voodoo 1
- CT3990
Somebody sat down on the CT3990 😠 But at least sound output is working perfectly 😲
The attachment IMG_7882r.jpg is no longer available
Reply 18971 of 58840, by meljor
I have the Sl2Z4 version, maybe the conversion ones are more compatible with desktop boards? Who knows..... Recently i bought a Fic 503+ Via mvp3 ss7 board and ofcourse i tested it with the Tillamook. It posts but only boots when l2 is disabled so up to now i have had no succes with ss7 boards and this cpu and no succes with Intel chipsets either..
Reply 18972 of 58840, by cj_reha
Predator99 wrote:
Primax AltraSound Soundstorm Wave and GUS PnP. GUS sold as defective but working :cool: Courisously only no sound when using RO […]
- CT1350B
- Mozart
- Voodoo 1
- CT3990
That Asus SCSI/soundcard is made for the Asus MediaBus, an expansion they put on some socket 7 boards.
Reply 18973 of 58840, by BloodyCactus
Picked up a Midiman MM401 (with its proper cable) off ebay for less than I expected. (interesting it has a 1993 pcb but a 1991 rom.. need to find a 2764 rom can I reburn the MCS8051 rom v1.15 into. Interesting its an 8031 which is a romless version, so it has no secret sauce internally, just the rom chip on the pcb.
I didnt expect to win so mm not sure I really need it 🤣!
Gonna have to turn midi off on my AWE32. I see the MM401 is set to use IRQ 2/3/5/7... 5+7 are used by the AWE. IRQ 2 is cascade to 9 which is ACPI.. which only leaves me IRQ 3... That also explains why in another vogon thread on MM401 people are saying to disable ACPI.. since its IRQ 9, that goes to IRQ2... which is the default..
Anyway, will try it on IRQ 3 and see how it goes.
Reply 18974 of 58840, by Nvm1
The voltage is also clear but the L2 cache not. Could it be they changed some of the pins of the Tillamook socket from a normal socket 7?
I am not deep enough into this kind of information digging but it could be a good explanation why the Tillamooks on Socket 7 don't work well cache wise?
I have atleast 10 socket 7 boards so I can de a good round of testing when I find time. I am mostly curious if I can get the max multiplier going on the Tillamook next to the question if there is a motherboard where the cache works with this CPU.
Reply 18975 of 58840, by stege
Sony SDM-S51 (Dec 2001) 😊
The attachment IMG_0438.JPG is no longer available
Miss the Monkey Island days, the Space Quest days, even The Longest Journey days.
Reply 18976 of 58840, by WildW
This beauty has been wrapped in plastic for nearly a quarter century waiting for me to play with it =)
Reply 18977 of 58840, by jheronimus
My quest for a good Socket 3 VLB board continues. Today I got myself a QDI V4P895GRN/SMT v1.0 (S1.1)!
The attachment 18488650.jpg is no longer available
This is my fourth VLB board so far. Generally, all my previous issues were related to the fact that I couldn't get AMD 5x86 to run the way it should, no matter how hard I tried.
This board uses an OPTi 895 chipset — relatively unpopular on Vogons (as opposed to SIS471, for example). As far as I know, it's a bit slower that SIS or UMC chipsets, but makes up for it in stability. Redhill Guide specifically names QDI's OPTI895 family of boards as its favourite. And there's a lot of stuff I like about it:
- 4xSIMM72 (no EDO RAM support, though);
- CR2032 battery;
- nice layout (no ISA cards are restricted by the CPU socket/cooler);
- AMI WinBIOS.
And, finally — the fact that it properly detects 5x86. The seller checked it with CHKCPU:
The attachment 18590589.jpg is no longer available
The attachment 18590590.jpg is no longer available
As you can see, the board works with both 4x33 and 4x40. Unfortunately, the BIOS calls 5x86 an "Am486DX4-Plus", but I guess that's okay — as long as the CPU works in clock-quadrupling mode.
MR BIOS catalog
Unicore catalog
Reply 18978 of 58840, by sf78
Recycling 30e. Not a great price, but these are quite rare here. Never seen any BBC micros anywhere and they had 3! 😲
Reply 18979 of 58840, by yawetaG
Hold onto this one. Several ASUS motherboards had optional proprietary SCSI cards that allowed the motherboard to boot from either IDE or SCSI (as opposed to only having SCSI boot with no devices attached to the IDE bus, like with regular SCSI cards), and this might be one of those cards. It will only work with specific motherboards, though.
