First post, by Vallenrod
Hello all,
If you had to choose one, two or three sound cards for an ultimate 90s DOS/Win9x gaming rig what would it be and why?
Not counting external Midi devices such as MT-32 but internal (Roland RAP-10) yes.
My vote goes to:
Single card:
SB AWE32 CT3900 (ISA non-pnp) Good DOS support, Wavetable header, works well with softmpu, no midi hanging note bug
Two cards:
Aureal Vortex 2 (PCI) only for windows, A3D
Three cards:
Gravis Ultrasound (ISA) (mostly for DOS demos and some DOS games, no windows stuff)
Reply 1 of 16, by firage
I agree with your choices.
I keep my GUS's to DOS/Win3.1x, though, so the third card I'd like to have working in a Win9x setup would be an Audigy. The older build can upgrade to an AWE64 for better quality SFX, an SB Pro 2 mainly for FM, and GUS Classic/ACE.
My big-red-switch 486
Reply 3 of 16, by Vallenrod
The 3 card setup works quite well, SB is at A220 I5 D1 H5, Gus is at 240,7,7,7,7 and Aureal has its SB Pro emulation turned off.
All com and parallel ports are disabled in bios and irqs 5 and 7 reserved for isa use.
More details here:
Making a GUS max 2.1 to work alongside a sound blaster 16
Reply 6 of 16, by Ampera
The ULTIMATE sound card setup for DOS, and even early Windows would be an AWE32 non PNP, or in a pinch a CT3670, with an MPU-401 card from Roland plugged into something like the MIDI mountain LGR did. An MT-32 and SC-55 would be I think the bare minimum for highest end PC MIDI, with the AWE32 using a real OPL3 chip having perfect support for everything else.
Reply 7 of 16, by firage
Both types of Roland MIDI are a high priority, but they're easy to replace with external modules. I don't think I personally rate the intelligent MPU interface over SoftMPU if it means losing higher quality glitch free SFX, real OPL FM or GUS support.
Man, the things you compromise with a mere three cards. 🤣
Reply 8 of 16, by gdjacobs
An AWE32/OPL3 card in combination with a GUS extreme would give you good coverage of PCM audio (including SB Pro support, for those titles that need it). An SCC-1A or LAPC-I would then give you synth with intelligent MPU. Of course, you need both GM and LA MIDI synth, so modules would be required at some point.
Reply 9 of 16, by NamelessPlayer
Single card:
-You mentioned Win9x, so I have to default to an Aureal Vortex2 card here. Gotta have that A3D, even if SB Pro emulation isn't perfect for DOS games.
Two cards:
-AWE32 non-PNP alongside the Vortex2, mostly for Eradicator and anything else particularly optimized for the AWE cards. Bonus points if the ASP/CSP is included for TFX's sake.
This is actually exactly what I'd do with my P4EE 9x/XP gaming build, but the current case I have it in (Lian-Li PC-61) won't fit the AWE32 in its bottom-most slot even with the hard drive cage removed, sadly. The resting brackets for said hard drive cage get in the way. I'd have to remove the rivets holding it in place without causing too much cosmetic damage to the case.
Three cards:
-XP isn't a factor here, so I can't say X-Fi like I have going for the aforementioned P4EE build. I suppose the natural choice for DOS would be a GUS or LAPC-I, preferably the former because there's always the option to use an external MT-32/CM-32L/CM-500, and there isn't a rule saying that you can't add external modules on top of those three sound cards...
Reply 10 of 16, by darry
1 card :
a)Any AWE32 or AWE64 without hanging note bugs
2 cards :
b)Any card with real OPL3, preferably an SB Pro compatible
3 cards :
c) Any member of the Gravis family (GF1 or Interwave based)
Bonus points for an SC-55 and an MT-32
Reply 11 of 16, by Ampera
darry wrote:
1 card : […]
1 card :
2 cards :
3 cards :
Some AWE32s have real OPL3. You can comebine cards 1 and 2
Reply 12 of 16, by darry
AFAIK and according to http://www.vogonswiki.com/index.php/Hanging_note_bug , only cards with DSP 4.05 or 4.16 are completely free of the hanging note bug, which again AFAIK excludes all AWE32s and SB32s except the CT3670 (DSP 4.16) . All AWE64 cards have a DSP 4.16 and are thus immune .
Reply 13 of 16, by Vallenrod
The type 2 bug must be very rare or hard to notice as I own my ct3900 for few months now and I am yet to experience it.
Reply 14 of 16, by firage
There's that and also the DMA clicking. Neither is a huge problem, but they don't exist on the AWE64's.
Reply 15 of 16, by olivil
1 card:
- AWE64 Gold: noiseless, amazing compatibility, no hanging note bug, supported by SoftMPU
2 card:
- AWE64 Gold
- GUS with 1024kB (Classic or MAX, tracker music, demos, cleaner sounds than SB)
3 card:
- AWE64 Gold
- GUS
- Real OPL3 card
Ideally all of these setups include an MT-32 and SC-55. 😉
Exactly my setup but sadly my mobo doesn’t have 3 ISA slots.
Reply 16 of 16, by Vallenrod
Can you imagine yourself saying this 20 years ago? Crazy huh?
