Reply 19880 of 58841, by Batyra
- Member
Thanks for replies. Memories on ET6100 are the same as on ET6000... what funny is that ET6000 is little faster than ET6100 in doom... I thought 6100 is faster.
Both ET6100 I have are "dark"... compareing to S3 cards I own, Brightnes on Tsengs ET6100 issignificantly lower. Can I do something about it? (I mean bios or some DOS software)... I only use them in DOS.
EDIT:
I have two chips with the same numer 908 but they doesn't work. If I place them in card speedsys shows still 2mb... But fortunately I will have two more "spare" chips and one of my ET6100 has 4 sockets - so I'll try to change all 4 od tchem if numbers will fit.
I just collect the hardware — others make it run.
