anthony wrote:forget it
one hour of designing pcb costs at least $60, to make mobo, even such as 486 it will take several hundreds of hours.
We have people on vogons who can and did design PCBs. There's a thread on the Video section with one member posting designs for a voodoo 3 on a dual layer PCB for example - and then there's the ARGUS project in the Sound section of Marvin. Sure, a motherboard would be a lot harder to make.
Personally, I'd pay up to 200$ for the following:
- Socket 3 486 motherboard
- ATX Form factor
- UMC or SiS chipset - maybe even a SoC like the ZFx86, with the option of disabling the CPU part and using a socketed chip.
- SD-RAM slots for memory, maybe even some fast on-board ram - 32MB is enough.
- Fast L2 cache packaged like the pipeline burst cache on socket 7 boards
- Plenty of PCI and ISA slots
- On board ATA133 IDE controller
- PS/2 for mouse and keyboard
- FSB from 20 to 66MHz, with proper dividers for 33MHz PCI operation
- CPU voltage support for 3.3v, 3.45v, 3.7v, 4v and of course 5v
- BIOS support for large drives
- turbo switch that forces the board to run @ AT bus speed (optional, but would be cool)
I guess the simplest solution would be to make something like this:
But in ATX form factor since AT cases are scarce in some parts of the world, and more PCI slots. The above board uses a ZFx86 SoC based on the Cyrix 586 core (I think - not 100% sure). The only issues with the above board is that it doesn't come with any L2 cache, and there's no way to add any - and it only has one PCI slot.
The cool part about the ZFx86 SOC is it's built on a modern manufacturing process, so it should be able to go faster then 133MHz. It supports 2x(4x) and 3x multipliers internally, and runs over the 33MHz FSB. I don't see why it wouldn't run at 2x66MHz, or 3x 66MHz for that matter. It would make for a really fun, fast 486 class machine to play pentium games on - think cyrix media GX with L2 cache and Fast FPU = ON.
