A strange ISA Card?
First post, by deksar
Hi everyone.
What does that (attached) ISA card do? That's from one of my IBM Model 30 286 PC.
Seems like an analog video output/capture to me?
Reply 1 of 24, by derSammler
That's a 10 mbit/s Ethernet card.
Reply 2 of 24, by lazibayer
That's how ethernet card looks like in 286 era.
Reply 3 of 24, by cyclone3d
Specifically, token ring. Could be 2Mb or 10Mb.
There were also 10Mb Ethernet cards that used the RJ45 socket, and also some that had both the BNC and the RJ45 socket.
disregard that.. I was being dumb.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 24, by derSammler
No, that's *not* a Token Ring card. It's quite easy to distinguish Ethernet from Token Ring.
Apart from that, it says Ethernet even in the PCB...
Reply 5 of 24, by Jepael
Definitely not token ring but standard 10Mbit/s coaxial ethernet.
I knew 10BASE2 ethernet was called cheapernet, but that's the first time I've seen it printed on a product, priceless 😀
It looks like the card can be jumpered to be compatible with NE1K, NE2K or WD cards, but I could be wrong though.
Reply 6 of 24, by brostenen
Yes. 10mbit coaxial. You need a T-Plug on each network cards, and connect the cables onto the T-Plug.
Then you need to attach a terminator on each ends of the network.
http://www.networkmuseum.net/2011/05/coax.html
Reply 7 of 24, by Errius
How do you connect such a card to a modern ethernet network?
Is this too much voodoo?
Reply 8 of 24, by cyclone3d
Blah.. got my network types mixed up.
YMF7x4 Guide
Reply 9 of 24, by brostenen
I too remember Token ring as something else. I can't recall how exactly the plugs used to look like, though I clearly remember stiff cables that were some 2 or 3 time thicker. By that, I mean really heavy duty and stiff cables, that were problematic to work with, because of that. I only had the pleasure of installing a token ring once, and that was back in 1995 and I have never ever had this between my hands since. I could be wrong about this, when I say that I recall some qube shaped plugs or something. Hmmm... Well... It was IBM machines in a token ring. And that Token ring was connected up to a bridge, and that bridge were connected to a thick yellow cable using some kind of spikes or something.
Anyway... 30 minutes of looking and connecting network cards to the ring, is not much to recall by in 2017. It was 1995 after all. 🤣
Reply 10 of 24, by Koltoroc
short answer: You don't.
Long answer, You don't want to. there are (or at least used to be) adapters that can connect BNC Ethernet to a switch. Assuming they are even still sold or you can find one at all, chances are a new ISA NIC with RJ45 port is likely much cheaper than any adapter you can dig up.
Reply 11 of 24, by Maeslin
Good old vampire taps. 😁
You might be able to find an ancient ethernet hub that has both kinds of connectors? I know I've seen a few at work while doing some spring cleaning. Note that those are hubs, not switches. I'm not even sure switches existed back then.
Reply 12 of 24, by brostenen
Ohhh yeah... That thick yellow cable (Thick Ethernet). A bitch to lay out right above a ceiling when you only have a step ladder. 🙁 I remember we used a 386 with two 3com netcards and a boot-floppy, to make a very unstable bridge to the coaxial cable in our classroom. The bridge had no harddrive though. It wass an old IBM XT case, that was reused with a generic noname 386 motherboard. It was headless as far as I remember, and we were told not to touch the stuff, as all the network components was expensive as hell. Oh well... We just tried to revive an old IBM 286 Xenix server instead of helping the tech people install and set the bridge and vampire taps up.
Reply 13 of 24, by Maeslin
As far as vintage networking gear goes, I kinda wonder if anyone here is still screwing around with the more exotic ones like Token Ring, ARCnet or TCNS
Reply 14 of 24, by gdjacobs
Maybe one of those guys playing around with Cray stuff can get a HIPPI link going.
As for using 10base2, you can also use a repurposed PC to bridge between a coaxial and twisted pair segment.
Reply 15 of 24, by yawetaG
By hooking it up to a computer (server) that has a card for both standards.
Reply 16 of 24, by Predator99
Yes 10mbit coaxial. This is a nice card as it has Jumpers and you dont have to mess with PNP configuration or to find the manufacturers config tool.
For connection of Coax to a TP network I recently got a converter (5€ incl. shipment). I also tried to install a 2nd Coax-PCI-card in my Windows 7 64 machine for routing, but its difficult (impossible?) to find drivers for it.
Reply 17 of 24, by derSammler
Old hub with both types of connectors, or media converter. Or just get a card with RJ45. 😉
Reply 18 of 24, by FesterBlatz
Does FDDI count? https://en.wikipedia.org/wiki/Fiber_Distribut … _Data_Interface
I still occasionally use an old Cisco 4K series router with FDDI interface installed. I use this for bridging my Ethernet LAN over to a 100meg FDDI ring that connects to my SGI Crimson RE.
Reply 19 of 24, by Predator99
As said this one works perfectly. But I will still try to find a Coax-PCI card that works under Windows 7 to get rid of this additional wires...
