Reply 21060 of 58849, by Predator99
derSammler wrote:
79L05 is not a transistor but a voltage regulator. It takes +12V input from the wavetable connector and outputs -5V.
ps: you need to check U1 and C13 (damaged -> replace)
Thanks!
C13 seems to be OK, only a scratch on the surface. Lokks worser on the photo than it is.
For U1 there seems to be a "second" connector pad with 4 pins which is unsed. It looks the same on the reference photo
http://www.amoretro.de/2011/06/terratec-waves … 24-ver-2-0.html
So I think both is OK.
Reply 21061 of 58849, by derSammler
Might be just the light, but on the picture it looks as C13 has a small dent in the middle. In this case, it must be replaced as it would cause a short inside the cap.
U1 is skewed. Soldering points are not original, it was probably re-soldered in the past. The upper four pins seem to have too few solder, the other ones have too much. I would de-solder it, clean the pads, and re-solder it properly.
Reply 21062 of 58849, by Predator99
Ahhh...I think I have to focus more on the selling of parts not fitting in my collection in the next time otherwise I am running out of space 🤣
Seller accepted my buy-at-once offer, told its most probably working:
2x 286 Mainboard: Morse KP-286 Suntac and VLSI
The attachment Clipboard02.jpg is no longer available
EGA/VGA Grpahics card and 8 bit Ethernet
The attachment Clipboard03.jpg is no longer available
The attachment Clipboard01.jpg is no longer available
2x VLB VGA with missing RAM...will see
Reply 21063 of 58849, by derSammler
Today:
- Pentium 66 from first batch with FDIV bug
- a nice ATX case with a Celeron 733 inside 😉
Reply 21064 of 58849, by furan
DaveJustDave wrote:
picked up a matrox power VR card today. Do you think it'll play nice with a voodoo 3? […]
Yes.
Reply 21065 of 58849, by CkRtech
Definitely probably maybe.
Reply 21066 of 58849, by KCompRoom2000
Today, I received this Intel Pentium III-S 1.13 GHz CPU for my GX150.
The attachment IMG_1734.JPG is no longer available
It works perfectly. A big thanks to the person who sent me this!
Reply 21067 of 58849, by JeffBai
Final pieces came in today to complete this butterfly!
Why does img=640x480 tag not work? Thought it was part of bbcode...
Reply 21068 of 58849, by probnot
Add a lower case L at the end of the filename in the imgur url (before the .jpg)
Reply 21069 of 58849, by yawetaG
The card on the right is not missing its RAM, but has upgrade sockets for adding additional memory, as far as I can see.
Reply 21070 of 58849, by easy_john
That image so big, that break my monitor!
PS Looks like another Ru member?
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 21071 of 58849, by JeffBai
Thanks!
Reply 21072 of 58849, by JeffBai
Sorry about the size, seems like the forum doesn't use the newest bbcode. But no, I'm not Russian myself... I'm a Chinese student of Russian major 🤣.
Reply 21073 of 58849, by bjwil1991
JeffBai wrote:
Final pieces came in today to complete this butterfly! […]
The butterfly ThinkPad. That's amazing to see that.
Reply 21074 of 58849, by cyclone3d
This lot of floppy drives for about what a single tested 5.25" floppy drive normally goes for on eBay.
The attachment floppy_drives.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21075 of 58849, by Ozzuneoj
Holy crap... that's a lot. Have fun testing them! 😀
Reply 21076 of 58849, by CkRtech
Center stack - middle: I think that is a Compaq?
Reply 21077 of 58849, by KCompRoom2000
Well, this week has been a lucky week for my Dell GX150.
Yesterday, I found a CL listing for NIB Dell M782 (not M782p) CRT monitors, I called the seller and they told me that they had plenty in stock and were willing to sell me one for $20. Today, I came to pick it up and brought it home new in the box (as previously mentioned if you're used to abbreviations).
The attachment IMG_17352.jpg is no longer available
The attachment IMG_1736.JPG is no longer available
The attachment IMG_17372.jpg is no longer available
Now I have a backup monitor in case my old M782p dies out (the lifespan is questioned due to the hissing noises). CRT monitors are getting harder to find these days so I decided to seize the opportunity to get an extra one.
Reply 21078 of 58849, by Cyrix200+
I really wanted this model case, so when a complete system with it showed up I bought it. I paid a bit more than I wanted to, but I am happy to have it. It is in really good shape and rest of the system is also quite nice. Someone put a lot of work in restoring and building it, it is super-clean and runs very well.
486SX 25MHz
8MB memory
SoundBlaster AWE 32 CT
I had forgotten how compact & cramped the case is, and the motherboard is in 'upside-down'.
More pictures here (some by the seller). https://imgur.com/a/IY7FF
1982 to 2001
Reply 21079 of 58849, by martin939
Ahahaha, you're the one who snatched it! The seller got like double he asked for.
I let it go because it had a soldered CPU.
