Reply 21340 of 58836, by Predator99
Yes, maybe the other cards are also good soundcards, but I think they are nothing difficult to get and I would not have bought such lot for them.
Additionally, I am not really collecting these cards because they do not look "nice". I prefer larger cards with more ICs on it compared to these rather modern and highly integrated ones 😉
Reply 21341 of 58836, by appiah4
Terratec cards are often pretty difficult to get for a good price, if you have any you want to dispose of let me know 😵
Reply 21342 of 58836, by derSammler
badmojo wrote:
I'm always on the lookout for a new sound card to play with - what's so good about these would you say? I seen an OPL3 on there and some mention of OPL4?
I don't see a wavetable header though.
There's the OPL3 version which has an OPL3 (obviously) and can be extended with an OPL4 wavetable. And there's a version that has the OPL4 already on-board. Why I like it? First, it just works. Drivers are nice and small. When the driver inits the card, a sample is played so you always know whether or not the card is working and your speakers are on. 😉 Then there are internal headers for all jacks, so you can do quite a few cool things with internal audio routing. The headers are auto-switching. Moreover, it has all important CD-ROM interfaces from that time. Important for me, as I'm collecting old CD drives and not always want to install the interface card for testing that came with a drive. And finally, the card just looks great. Nice and clean PCB layout.
Reply 21343 of 58836, by appiah4
Grabbed a couple SB Live! cards because they were listed as $3 a piece, so why not; they are always a good choice for Win9x/XP builds, especially with an ISA/PCI OPL3 card.
Creative_Sound_Blaster_Live_5.1_SB0100.jpg Creative_Sound_Blaster_Live_Player_CT4830.jpg
I also got this Coppermine 1000B for $5 because why not, it's basically the best CPU you can stick on a 440BX board. This one turned out to have some chipped sides and corners though, let's see if this one will actually work or not. I've seen worse banged up P3 cores soldier on, and less chipped cores crash and burn, so, we'll see..
Reply 21344 of 58836, by bristlehog
Batyra wrote:
Interesting. Can you tell a little more about it?
It's a variant of IBM M-Audio Capture and Playback Adapter (M-ACPA). Does 16-bit PCM sound and FM-like synthesis. It has DOS and Win 3.1 drivers, can play MIDI files. A video about MCA variant of the same card: https://www.youtube.com/watch?v=qkk0YW_qd-Y
There are beta drivers for Win 3.1 that add SB compatibility.
We have started a thread about it: Tecmar ARPA sound card
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 21345 of 58836, by gdjacobs
Looking a little deeper, I'm no longer thinking it's a Terratec board. Probably from these guys:
http://www.globalsources.com/si/AS/Techmakers … panyProfile.htm
Still, Crystal PCM audio chips usually sound nice and clean.
Reply 21346 of 58836, by derSammler
derSammler wrote:
Bought a Compaq Deskpro today. Not sure which model, but it's a Pentium 2-based desktop.
Arrived today. 😀
Reply 21347 of 58836, by Predator99
Predator99 wrote:
My GUS lot... […]
My GUS lot...
...just arrived 😎 Its a 2.4 and looking quite good. Will test it tomorrow.
The other soundacrds are nothing special:
Then some graphics cards along with a Mach64 PCI, also nothing special...but have to check for the STB Horizon 64, never seen this card:
But I think for 50€ I made a very good deal for the GUS.
And no, I dont see what should have been unfair in this deal und I would do it again that way... 😈
Just tested the GUS....woking fine 😎 😎 😎
Reply 21348 of 58836, by Predator99
gdjacobs wrote:
Looking a little deeper, I'm no longer thinking it's a Terratec board. Probably from these guys: http://www.globalsources.com/si […]
Yes, there is a label MF-4236PQ on it, so its this card
http://stason.org/TULARC/pc/sound-cards-multi … -mf-4236pw.html
Not of high value:
https://www.ebay.com/itm/Scheda-audio-slot-IS … =p2047675.l2557
Reply 21349 of 58836, by chose007
martin939 wrote:
Hooold up, Dual Pentium PRO 256k?
You right 😀
(jurassic park allready cleaned)
and some new cards, not so old but top interesting models
Tseng 6000 and SiS 315
8800U + GTX260
same like Quadro
6800U AGP
Reply 21350 of 58836, by Cyrix200+
appiah4 wrote:
<snip> […]
<snip>
PIII's are quite resilient to just chipped sides/corners, but you never know. Running it on a 440BX would be overclocking the AGP. You would need a non-B with 100MHz FSB.
1982 to 2001
Reply 21351 of 58836, by Batyra
Just got it. AFAIK the best and lates intel based Socket7 board from Gigabyte.
It gonna replace my GA-586ATX (but without 4 in the end, it lacks 75FSB and has botd simm and sdram).
I just collect the hardware — others make it run.
Reply 21352 of 58836, by oeuvre
Got this Intellistaion M Pro. Bit of a mystery machine! Will post when it arrives. https://www.ebay.com/itm/263339029458
Reply 21353 of 58836, by chose007
Mystery is 2x P2 slot1 and LX440 chipset in it 😀
Reply 21354 of 58836, by oeuvre
Hopefully it comes with drives
Reply 21356 of 58836, by blurks
maverick85 wrote:
omg yes. where did you nab these from?
I got them seperately from different sources. To be honest I find it pretty challenging to track down the main office programs in their retail boxes in acceptable shape. They are not particularly expensive when they pop up but they are not plentiful. It seems people had no reason to buy Word, Excel or PowerPoint seperately when they could have gotten the Office suite for a comparable price back then.
Reply 21357 of 58836, by keropi
I was gifted this 486/66 tower this week:
486/66 , 540MB HDD, 8MB RAM, some OPTI soundcard and a VLB Trident 9400cxi vga - pretty much the usual stuff one would buy here at the time 😀
Reply 21358 of 58836, by luckybob
Got a very good deal on an IBM Eququest model 55.
Basically it is an all-in-one, 486 machine that was marketed at schools. Came with an original (not lexmark) Model M keyboard. I'll probably post an unboxing video and subsequent restorations!
Reply 21359 of 58836, by cyclone3d
An S3-928 based ISA VGA card for my 386DX-40 build. Paid a bit more than I would have liked, but it is boxed and is a 2MB card and one of the fastest chipsets that was available for ISA.
And it was not much more than the bog-standard slow ISA VGA cards available right now.
The attachment box.jpg is no longer available
The attachment card.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
