psu help for win 98 - xp gaming
First post, by Robhalfordfan
hi all
I am looking for a new psu my win98 - xp build and need some help
will needing a psu that goes at top of case because of the case I will be using
not sure about total wattage I will be needing
I am gonna be using:
AMD Althon 3200+ processor
Nvida 6800 Xtreme 256mb - AGP
DVD Rom/Re-wirter drive (possibly two maybe)
3.5 floppy drive
HDD x2 (molex most likely)
network pci card
soundblaster sound card (later model- not sure yet)
I am not worried about pci-e at all at the moment, ideally looking older atx psu with molex connecters (maybe one or two sata) incase i want to add more drives in the future
in all searching I cant find a decent/good psu the has more molex instead more sata and pci-e (which I am not worried at all about that)
Reply 1 of 24, by gdjacobs
Just to confirm as it's not mentioned, does your motherboard supply the CPU VRMs from the 12V rail? If so, you should be comfortable with a modern ATX12V PSU.
Reply 3 of 24, by gdjacobs
That board is designed for 5V heavy loads, so you'll need to source an appropriate ATXv1.3 power supply.
Reply 4 of 24, by Katmai500
The Startech ATXPOWER300 (~$35) seems like a decent brand new option for these 5V-heavy systems. 30A on the 5V rail and only 15A on the 12V. It's ATX 2.03, but seems to have enough power for an Athlon XP build. It's rated for 180W on 3.3 + 5V.
Reply 6 of 24, by Katmai500
The 6800 should draw from 12V on the molex connector. Max power delivery for a single molex connector is 11A @ 12V, for 132W. The AGP spec allows for ~42W max on the slot (from a combination of the 3.3V/5V and 12V). So if the card only has a single molex connector you *should* be under 180W on 12V, and have about 150W free on 5V for the CPU and other 5V components. The card may also draw some power from the 5V rail on the molex connector, which I haven't accounted for here. So it will probably work, but you wont have a lot of headroom. I'd try finding something with a bit more power output, and fallback to the 300W unit as a last resort.
Reply 8 of 24, by Katmai500
The recommended power supply rating on most GPUs is very high as a safety margin for the manufacturer.
A 500W power supply won't be overkill. The problem is you need to find a power supply that can handle a large load on the 5V rail for that Athlon XP. That 3200+ has a TDP of ~80W. Modern power supplies don't handle large loads on the 5V rail very well. A modern 500W power supply with a 25A 5V rail might handle it, but you are cutting it very close.
Reply 9 of 24, by Robhalfordfan
I just want to make sure everything would be ok and run as smooth as possible and the rig to suppose to between old skool and modern
my dos-win95 rig is old skool
this rig of the in middle
my win 10 rig is modern rig
Reply 10 of 24, by Radical Vision
I recommend using any old EnermaX power unit or Delta, they work best for me, and the build quality and the power delivery is superior...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 12 of 24, by gdjacobs
Robhalfordfan wrote:
ok would work for what I need cause i know its bordering the old and modern hardware
Just stick with a reliable manufacturer and make sure the +5V and +12V label ratings are beefy enough. Please be aware that you might have to perform some recapping if you choose a used PSU.
Here's some options for you to look for:
The PSU Matchup Thread
Reply 14 of 24, by Radical Vision
Well 400W Delta PSu or EnermaX, Seasonic will be ok for your system, you need just 25-30 amps from the +5v..
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 15 of 24, by Robhalfordfan
would any of these do
https://www.ebay.co.uk/itm/Enermax-EG465AX-VE … 6EAAOSwBV5acGpL
https://www.ebay.co.uk/itm/Delta-Electronics- … 4YAAOSw0e9U1hvF
https://www.ebay.co.uk/itm/Delta-DPS-450DB-S- … ~gAAOSwonBaDvBd
Reply 17 of 24, by Radical Vision
All of them, as im not sure if that 2 Delta units are proper size, also if they will work with normal motherboards, as i have here similar Delta from HP station that is 465W, is little bigger, and 80% of all motherboards just does not work with that PSU as the wires on the 20 pin ATX connector are changed.... This with all these 3 EnermaX unit will be ready to go when you get it, no problems, but it have inferior quality of the caps, while the Delta units have japan high quality caps and they will be more stable and last way longer, but they can have the problems i mentioned... But i think you will be ok to go with the EnermaX.
Katmai500 wrote:
That Enermax looks excellent
And it is, i have one of those in the machine i did build for a friend, is rock solid, BUT the caps inside are not japan ones......
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 18 of 24, by Robhalfordfan
I never had an issues with caps before as my older rig for dos gaming use a 200w AT psu and not any issues with it
would 450w be enough to power everything that will in it and any thing else I might want to add or upgrade in future
Reply 19 of 24, by Radical Vision
Yeah as im using 400W EnermaX Liberty on my 462 machine where it have ATi Radeon HD3850 AGP and Clocked AthlonXP-M on 2.6GHz rock solid...
    1.99 MiB
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
