Reply 22040 of 58779, by luckybob
I'm hungry now. 🙁
Anyway, back on topic, I just bought this guy for my IBM eduquest: https://www.amazon.com/gp/product/B01CMYIRMO/ … 0?ie=UTF8&psc=1
I don't usually consider Amazon, but $32 shipped is a damn sight better than the $75+shipping that cockwomble on ebay wants. I'm standing on the precipice of adding a token ring segment to my network.
Reply 22041 of 58779, by dionb
luckybob wrote:
I'm hungry now. 🙁
Ah, brings back memories. Are you going to go the whole hog with ICS cables & MAU, or will you be using RJ45 to keep wiring manageable?
Reply 22042 of 58779, by luckybob
Well, I have a box of type 1 cables, AND the rj45 adapters, so it can go either way. At least one will be used, as the linked card only had the 9-pin connection. I have the IBM 8228 MAU, some pci and isa cards, and a buttload of unanswered questions. I'm just going to slap it all together and hope I can finger it out from there. I heard about getting a special device to manually reset the MAU and I can probably jury-rig something together if need be.
I will fully admit we are damn spoiled by modern ethernet.
Reply 22043 of 58779, by dionb
Last time I worked with that stuff (but that was quite a while ago...) "it just worked", using ICS/Type 1 cables and that same 8228, although I was using slightly more modern Madge PCI 16/4 cards, I could just configure layer 3 and higher and that was pretty much it. But I don't even remember which OS I was using then, let alone the rest of the software situation.
Reply 22044 of 58779, by blurks
More stuff for the collection. 4 new ASUS cards to accompany my V8200. Especially like the V8460 and its colors - also extremely heavy.
Reply 22045 of 58779, by The Serpent Rider
Lookie-lookie what I've got:
The attachment Gigabyte box.jpg is no longer available
The attachment Box inside.jpg is no longer available
The attachment Gigabyte GA-686DX.jpg is no longer available
The attachment 192mb EDO memory.jpg is no longer available
2 Pentium Pro 200mhz 256kb, Gigabyte GA-686DX, 192mb EDO ram.
Good:
- Interchangeable RTC
- All japanese caps
- 6 SIMM slots
- Can be overclocked up to 266mhz
- ATX with USB
Bad:
- 60-66 FSB only, unless I'll find some undocumented options for PLL.
- Not sure if Pentium Pro 1mb is supported.
P.S.
Joined the Dual Pentium Pro club 😈
Reply 22046 of 58779, by Batyra
Have not posted anything for some time but today postman broungt me some goodies...
IBM Music Feature Card 😎
The attachment Batyra_IBM_MFC.jpg is no longer available
CT1950 AWE64 24MB (?) Memory Upgrade
The attachment Batyra_CT1950.jpg is no longer available
CT1330A the original (first) Sound Blaster PRO (not the quite popular CT1600 SB Pro2)
The attachment Batyra_CT1330A_SBPro.jpg is no longer available
2x NOS ATX Desktop Case... real retro no USB od sound front panel - This will be home for my two main retro builds
The attachment Batyra_Desktop.jpg is no longer available
I just collect the hardware — others make it run.
Reply 22047 of 58779, by uzurpator
The Serpent Rider wrote:
Madly jelly. I want this for the sake of having it.
Die ewigkeit ist hier und jetzt.
Reply 22048 of 58779, by Baoran
My graphics card arrived today. Not a bad card for 20 euros including shipping. Now I almost have all the parts for my next build.
The attachment 20180221_171119.jpg is no longer available
Reply 22049 of 58779, by havli
I have the single CPU vesion GA-686NX, solid board. Yours looks very similar.
Shame it has the RTC chip and not regular CR2032 battery like Intel boards for example. I don't think 66 MHz is a negative... are there even i440FX boards that can do more? Also most (if not all) PPro tops out at 233 or 240 MHz. 266 is very hard to reach.
Reply 22050 of 58779, by The Serpent Rider
Personally, I see real problem only with soldered on board RTC chips. This board have socketed RTC and those are easy to modify/replace.
Some have 75mhz FSB option for early 150mhz models (75x2)
Not with liquid nitrogen 😀
https://overclockers.ru/lab/show/77627_3/retr … pro-socket-8#11
Reply 22051 of 58779, by luckybob
As the de facto leader of the Dual cpu-club I welcome thee.
Reply 22052 of 58779, by Scubs
REMVING POST FOR MY OWN SAFTY
Reply 22054 of 58779, by Bancho
I have the exact same case. Its a great case. Very well built!
This Keytronic keyboard showed up today. Its in great condition and seems really well built.
Reply 22055 of 58779, by arncht
Creative Sound Blaster 2.0 CT1350 ISA
DSP2.02, YMF3812 OPL2
Aug 1991
The attachment 20180221_203021.jpg is no longer available
Creative Sound Blaster 16 ASP CT1740 ISA
DSP4.05, YMF262 OPL3
Jun 1992
The ASP or CSP chip added some new features to the Sound Blaster line, such as hardware-assisted speech synthesis (through the TextAssist software), QSound audio spatialization technology for digital (PCM) wave playback, and PCM audio compression and decompression.
The attachment 20180221_202056.jpg is no longer available
Overdoze of the demoscene
Reply 22056 of 58779, by Batyra
@Bancho
Nice! and I got that Pioneer DVD too 😀 almost identical 😀
Reply 22057 of 58779, by Mcstfuerson
Great find on the Ti4600.
The heatsink on the other ASUS model V8460 Ultra is pretty goofy looking
Reply 22059 of 58779, by oeuvre
me irl
