Best 386 Motherboard?
Reply 180 of 287, by Tiido
I have that board in my 386, with the same ULSI 387 and 20MB RAM. 64KByte SRAMs are physically larger so they will not fit the sockets but with mods it would be possible to have up to 512KB cache (I have seen industrial boards with the chipset that have 512KB cache). Now if pinout could be located it shouldn't take too much effort to boost cache. That chipset is also supposed to support PCI and VLB too.
Reply 181 of 287, by chrisNova777
does cache make a huge difference in performance? because i only have 128kb in both my 386 + 486
Reply 182 of 287, by kixs
Doubling the cache can get you around 3-5% increase in performance. It pretty much depends on the app used.
Reply 183 of 287, by Anonymous Coward
512kb cache is incredibly rare on 386 motherboards. Usually the chipsets that support that much are the hybrid type and will only support 512kb when a true 486 CPU is installed. The closest I can think of at the moment is that Alaris Cougar motherboard that reportedly works with 512kb with a 486BL3 (386 type).
Reply 184 of 287, by Jupiter-18
I've been looking for an Alaris Cougar for ages. That is for SURE on my wish list. I've heard amazing things about the 486BL3. It has VLB too.
Reply 185 of 287, by Anonymous Coward
I saw one on ebay the other day for around $100.
https://www.ebay.com/itm/Alaris-Cougar-II-Mot … =p2047675.l2557
Reply 186 of 287, by Jupiter-18
Aw dang, it's over already.
Reply 187 of 287, by timb.us
128k should be plenty on the 386. Unless *really* want the extra 1% performance boost you’d get from upgrading to 256k or already have the cache chips, it’s really not worth the money. Going from no cache to 64k is a huge performance boost. Going from 64k to 128k gets you about a 5% boost. Going from 128k to 256k gets you an additional 1 to 2%. (*Typical results, some specific apps may benefit more, by not by a lot.)
Any sufficiently advanced technology is indistinguishable from magic. (E.g., Cheez Whiz, RF, Hot Dogs)
Reply 188 of 287, by feipoa
I see a funky blue ZIF. Do you think a board like that could use a PGA-168 SXL2 with the Cyrix FasMath?
Reply 189 of 287, by The Serpent Rider
Did some research on my Forex 386 board. Apparently Forex 46C521 is 486 VLB chipset too.
Reply 190 of 287, by Anonymous Coward
Unlikely, but it wouldn’t hurt to check the user manual.
Reply 191 of 287, by Skyscraper
Finally here is the MR BIOS for the "OPTI 386WB" a.k.a Shuttle HOT-307.
Speedsys refuses to dump a BIOS without a working HDD in the system for some reason although it dumps the BIOS to its own the directory on the floppy... that's the reason for the delay.
I also made a new BIOS dump of the OPTI 391 i486 MR BIOS just in case something was wrong with the old one and replaced the file in the message two pages back. I will also post it here.
Both files are dumped with NSSI using a clean DOS 8 boot disk.
OPTI 391 i386 MR BIOS. From a working generic OPTI 391 "OPTI 386WB" motherboard.
OPTI 391 i386MRBS.zip
OPTI 493 i486 MR BIOS. From a non working generic OPTI 493 "ST0486WB" motherboard. The BIOS (chip) works perfectly fine with the Shuttle HOT-403 OPTI 493 i486 motherboard I used for dumping the file.
OPTI 493 i486MRBS.zip
Don't try these BIOS files unless you have a way to recover your old BIOS in case it dosn't work!!!
Edit
repaced BIOS files and some faulty information
/Edit
Reply 192 of 287, by timb.us
Skyscraper wrote:
Finally here is the MR BIOS for the "OPTI 386WB" a.k.a Shuttle HOT-307. […]
Both files are dumped with Speedsys using a clean DOS 8 boot disk. If for some reason Speedsys makes non functional dumps I will try to find a better utility.
OPTI 391 MR BIOS i386 .rar
OPTI 391 i486 MR BIOS. From a non working generic OPTI 391 "ST0486WB" motherboard. The BIOS (chip) works perfectly fine with the Shuttle HOT-403 OPTI 391 i486 motherboard I used for dumping the file.
OPTI 391 MR BIOS i486.rar
As both motherboards seems to be reference design boards and they both have WB in the name I guess either WB dosn't stand for "Write Back" or more likely reference design OPTI 391 motherboards use a write back L2 caching scheme.
Sweet, thanks! I’ll give this a try tonight and report back!
Reply 193 of 287, by Skyscraper
I did a quick search and I'm now pretty confident that the OPTI 391 chipset is "write back" L2 only so L2 caching scheme shouldn't affect BIOS compatibility between motherboards with this chipset as all boards should be "WB".
The "WT" version of the chipset seems to be called OPTI 381 as seen on this motherboard.
OPTI 381 386 "WT" motherboard. The picture is "stolen" from an Ebay auction. If you own this picture and want me to remove it just send me a message.
Reply 194 of 287, by Jupiter-18
The board arrived safely! I will send pics soon!
Bottom line, all seems to be in order. The battery has leaked a minor amount and some traces are a bit blackened, but i removed the battery so no more can occur. Additionally, the seller ensured me this board was fully functional, so I'm not worried. This board has external battery support, so I'll just use one of those.
Should i bother with trying to scrub up the traces that were affected if the board works fine without it?
Reply 195 of 287, by The Serpent Rider
You should, corrosion will slowly destroy this traces.
Reply 196 of 287, by Jupiter-18
Alright. How do?
Reply 197 of 287, by quicknick
My method: apply mild acid on the affected area. Vinegar is most convenient. Apply with syringe or cotton swab. You might see some foaming if the battery spill is still recent. Wash away the vinegar: isopropyl alcohol works wonders. You can use water if you leave the board to dry thoroughly. After it dries, gently scrap away the solder mask (lacquer) from the affected traces and check to see if they are broken or not. A multimeter is handy at this stage.
Hope it helps.
Reply 198 of 287, by Skyscraper
Hope it helps.
I only do step two if the board dosn't function properly. I use plenty of vinegar in step one and any discoloured parts under the solder mask not exposed to the vinagar isn't exposed to oxygen either so with the battery gone the plague shoudn't spread.
I only remove the solder mask if I find that I need to fix broken traces and even then only if it isn't more convenient to just add a bodge wire. Perhaps it's just me beeing lazy but so far I have not seen any corrosion speading after I have removed the battery and scrubbed the affected area with vinegar.
Reply 199 of 287, by quicknick
Indeed, i should have mentioned. The solder mask should only be scrapped when it is obvious that the battery goo has seeped under it (and it becomes discolored/brittle/scrapes away very easily).
