Reply 8240 of 30894, by brostenen
- l33t++
Cleaned the read/write heads on two Amiga floppy drives (one for a500 and one for a600). Now they work again. 😀
Cleaned the internals of my a500 with some alcohol, and had a look at the motherboard.
It is an revision 8a (or 8a1 or something with "a" and "8" ) It has ECS, space for internal battery clock, and pads for 1mb ram.
Yet this board has kick 1.3 and only 512k of internal mem. I was under the impression that late a500's only used up to
revision 8.0 and not something with an a in the revision number. Must be one of the absolute last 500's before it was all 500+.
This only gives me some room, for improvements. As I have a 2.xx rom in the closet (37.300) that I can use with a kickrom
switcher. I can upgrade to 1mb chipram or find a 8mb that sits under the CPU.
Or I can find a kipper2k board, with 4 or 8mb ram, that has IDE/CF-Card slot. Will become a great a500. 😜
EDIT:
Had an ekstra look at the board.... Yup... It is an "Revision 8a.1"
