First post, by Aglenoth
Hello gentlemen , I have boight old tft screen tecra however i have to press screen from back to get clean image as seen in photos , i thought about placing something behind the LCD , but i dont want to bend lcd.
Any help os higly appriciated 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 1 of 1, by 133MHz
Might be a cold solder joint or a broken trace on the LCD board - long ago I had a Powerbook 145 which suddenly developed black jailbars on the bottom half of the screen, I took the LCD apart and with the computer on and displaying an image I started poking at everything on the boards surrounding the display panel, found out when I touched an interconnect said jailbars turned white. I followed that with a multimeter and turns out a trace had gone open circuit - jumped it with a bit of wire and that fixed the screen. 😀
http://133FSB.wordpress.com
