Reply 23560 of 58393, by gdjacobs
Pabloz wrote:
gdjacobs wrote:
I want to try a CMI8330 card (or a SoundPro rebadge) but they're sometimes hard to find.
whats so special about cmi8330? it looks like another cheap card from taiwan.
Full SPDIF output for both FM and PCM. Also, it has both SP Pro and SB16 compatibility.
Reply 23561 of 58393, by dionb
dionb wrote:
Just received confirmation I can go pick up two totally unknown old boxes for free. The seller posted a stock pic of an Amiga 1000 and stated "similar, but not the same, photo from internet" but added "extremely heavy", which is hardly how I'd describe an Amiga pizza box and 12" monitor. The mind boggles at what I'm exactly going to find there. Loot box ahoy 😉
Aaand... not my lucky day...
The "similar" to an A1000 with 12" monitor turned out to be two HP S7500 CRTs - rather late low-end affairs and in a bad state. I passed on the opportunity.
Then the other loot box: a Packard Bell Platinum ATX miditower with something in it. Given the ATX backplate I thought I'd found another MSI MS-6168, as it was the only board shipped in this case with the specific connectors (onboard audio in PC99 colours and one serial port replaced by a blue VGA connector). Nope. The previous owner had actually managed to downgrade the motherboard to something close to what would have been found in a low-end Packard Bell at the time: a Gigabyte GA-6VMML (Via PLE133, no AGP and generally crappy). The low-end PB would have had GA-6WMM7 (the i810 version of the same). Oh, and the caps are all bust too. Given the low price I paid (EUR 10...) not anything to complain about, but a disappointment nonetheless.
Edit: could have known this. The case is a Hercules (1998-vintage) Platinum tower, which should have had an Intel SE440BX or MSI MS-6119 in it - neither of which had PC99 colours or integrated VGA. And of course the previous owner was a smoker - my fingers stink again 🙁
Reply 23562 of 58393, by Artex
cyclone3d wrote:
Grabbed a poorly listed Ensoniq S-2000. […]
Sure hope it is OK.... why do people use carpet to lay electronics on when taking pictures? At least it isn't shag.
Looks like Gateway had these as an option.
Yup - a 1Mb ROM Gateway 2000 OEM version is what you have there. The 2MB ROM versions have the larger "MX" chip (in length) and are the retail versions that also typically have the IDE interfaces.
Reply 23563 of 58393, by cyclone3d
Which means I can do a direct comparison with my retail version 😀
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23564 of 58393, by Artex
For sure! The difference is subtle unless you have expert ears imo. The Elite is night and day compared to the plain S-2000, but primarily because of the attached DSP. If you've got one of these, then you have another for comparison! They all share the S2016 base model #.
Reply 23565 of 58393, by xjas
NO KIDDING. Huuuuuuuuge freaking pet peeve. Especially when they then go and demand premium prices and say things like "I know what I have." I don't want something that's been in the place where your slough along with your yucky feet and all the mice in your house use as a toilet. Put it on a desk or a table like a civilized human being. How hard can this be?? ARGHLGRFKLGLK;KF
Reply 23566 of 58393, by CarlHopkinsUK
So this happened today...
The attachment IMG_20180522_141751.jpg is no longer available
The attachment IMG_20180522_141737.jpg is no longer available
Found a nice NOS sealed Netgear PCI card in my stores today too 😁
Reply 23567 of 58393, by dionb
Compensated for my bad luck with old hardware this week by buying an Asus P5A system. Not picking it up till the weekend, so don't know the revision, but regardless it's a board I've wanted since these things were new (even if I now know a late rev GA-5AA is technically better). Also getting a nice ATX desktop case (1998-era AOpen by the look of it), another Diamond Speedstar A50, either an early revision SB 64 PCI or a late Ensoniq AudioPCI, a PCI modem (yay...), fast CDRom and slow CDRW, a Compaq 15" v55 CRT and a (badly yellowed) Packard Bell keyboard. Oh, and an otherwise unspecified HDD running Windows 98 - which proved that it all works, at least well enough to boot to desktop.
Apart from the motherboard not really anything special, but can't wait to see if I can get my K6-3+ running at 720MHz (and if it's a rev. 1.05 or later, then see how to hard fix the slowdown bug)
Reply 23568 of 58393, by meljor
I have three p5a-b boards and four p5a, all revisions. Tried two k6-3+ cpu's and two k6-2+. Getting any of these combinations with working cache above 630mhz i had zero luck. I also have the Gigabyte late revision (5.2), it is not better in any way as far as i know. Didn't even clock any higher as the Asus. It even was a fraction slower in benchmarks. The Gigabyte Ga5aa (baby at version) did a bit better but also slower as the p5a boards.
The absolute highest 3dmark scores i got from a 1.04 P5A-B
So good luck reaching 720mhz! Let me know if you got it.
Reply 23569 of 58393, by furan
Another console on a card, this time PC-FX. I have the 3DO Blaster, so now all I need is that ISA CD-I card.
I realize there are development cards for snes/psx/etc but I don't think I will come across them easily.
Reply 23571 of 58393, by The Serpent Rider
Hentai-ecchi engine card in your regular PC. Sweet.
Reply 23572 of 58393, by dionb
Turns out I was a bit too hasty and mis-identified the motherboard. It's a Gigabyte GA-6VEML. That letter difference means PLE133T and FC-PGA2, so Tualatin support. It's still crappy integrated VGA without AGP, but under the (dusty, smoky) heatsink I found a Celeron 1200, which is a nice surprise.
Shall do 😀
Reply 23573 of 58393, by CkRtech
Wow. Like others - Yeah. I had no idea! Nice.
Reply 23574 of 58393, by liqmat
furan wrote:
Another console on a card, this time PC-FX. I have the 3DO Blaster, so now all I need is that ISA CD-I card. I realize there are […]
Ya know, it's one thing to not know about a piece of obscure hardware like this, but another to not even know the hardware this hardware is allowing you to play on the PC. 🤣 Completely out of the loop on this one. Looked it up on Wikipedia to get filled in. So something like this would probably turn up on a site like Yahoo! Auctions is what I am guessing?
Reply 23575 of 58393, by Turbo ->
Got a few RAMs in the mail box today...
Reply 23576 of 58393, by yawetaG
Yeah, Yahoo Auctions Japan, or a Japanese Ebay seller (at a huge mark-up compared to Y! Auctions, probably).
There are three PC98 versions on Y! Auctions right now, the PC/AT version is much harder to find.
Reply 23577 of 58393, by Batyra
Just received this beuty… quite not standard colour as for s370...
The attachment Abit CASPER 2.jpg is no longer available
I just collect the hardware — others make it run.
Reply 23578 of 58393, by OldCat
Oh Casper, the friendly ghost... Is that for a white build?
Reply 23579 of 58393, by CarlHopkinsUK
Never had the opertunity to have a true 1600X1200 screen, as i jumped right into the 1600x900 widescreens and then FHD models. So when this turned up cheap i had to get it.
The attachment IMG_20180523_183254.jpg is no longer available
HP LP2065 20" in perfect condition. Wonderful LCD and fantastic compared to my great (but scratched) Samsung 19" 943 1280x1024 it is replacing...
