First post, by 0kool
I have found a few new old stock cheap AT cases with crappy PSUs, but don't feel too confident about it.
Used Seasonic, Lite-On, Acer, Dell etc on the other hand looks like a much better option. Any other good and relatively widespread brands out there? The local choices are limited, so I would hate to miss on some obscure but rock solid power supply.
Thanks
Reply 1 of 9, by dionb
Enlight always had a reputation for high quality and low noise (at something of a premium price). And I generally swear by FSP.
Reply 3 of 9, by appiah4
Channel Well is good I believe, they became Corsair's PSU manufacturer IIRC.
Reply 4 of 9, by cyclone3d
Unless the case will only support the old AT location of the power cable and switch on the power supply, I would use an ATX power supply and an ATX to AT adapter. You can even get adapters that add -5v if you need that.
New good quality ATX power supplies are much more efficient and have much cleaner power output than any old AT power supply.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 9, by gdjacobs
My Delta AT (Compaq OEM) is streets ahead of other power supplies I've looked at. Shame that the main power cords are only ~15 cms long. Still, it works well on a test bench.
Reply 6 of 9, by amijim
Seasonic has made superior AT power supplyes in the past.I just sold one with a TARGA NOS full tower.You will find good DELTA and Antec though.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 7 of 9, by badmojo
I use newly made Startech AT PSUs in all of my AT machines and they seem good.
Reply 8 of 9, by Errius
Are "Super Power" brand PSUs any good?
Is this too much voodoo?
Reply 9 of 9, by gdjacobs
What I can find doesn't give me a warm fuzzy feeling.
