Reply 24220 of 60068, by gdjacobs
LeFlash wrote:
Yes, soldering since roughly 25 years, but only 1.5 years with hotair and rework stuff. I just need a cold beer to get smooth ha […]
Cyrix200+ wrote:
That is a well-done repair. I assume you have experience and the tools for this? 😀
I would go SMP Windows 2000 with Voodoo 2 SLI.
I just need a cold beer to get smooth hands 😉
Here's another board (Socket 7, Via MVP3) where i replaced the Multi-IO, too. The old one was burned, don't know why. Cheap board from ebay
If you are curious, here's a video of me doing the repair. Unfortunately, the camera lost focus for some minutes until i noticed.
On this particular IC i soldered the pins individually, no big deal, just takes some more time but with sharp eyes you can be sure there are no solder bridges and you don't have to wick it afterwards.
https://www.youtube.com/watch?v=DkcfQztdPX0
Second board is here:
https://www.youtube.com/watch?v=iKxt51BpQj0
?interpolation=lanczos-none&output-format=jpeg&output-quality=95&fit=inside%7C1024%3A640&composite-to=*,*%7C1024%3A640&background-color=black
Reply 24221 of 60068, by luckybob
@LeFlash
tenor.gif?itemid=5345999
Reply 24222 of 60068, by Vegge
As usual, not just purchase of today, but the last week at least. 😀
Finally, MT-32 goodness 🤣
The attachment IMG_0285.JPG is no longer available
Picked this up, just for fun, sporting DX2-66, 20mb ram and AWE64
The attachment IMG_0304.JPG is no longer available
And this beast arrived today 😎 Looking forward to playing with it 😀
The attachment IMG_0306.JPG is no longer available
The attachment IMG_0308.JPG is no longer available
Reply 24223 of 60068, by bjwil1991
The Compaq computer looks like a YouTuber has reviewed and currently has it still. Amazing machine, but requires an external CD-ROM drive connected to the printer port (boo). I wish someone would make a slot bracket (add-on card) to install an IDE CD-ROM drive externally for machines like that (would be awesome) using an IDE cable and a Molex connector.
Reply 24224 of 60068, by Cyrix200+
Vegge wrote:
<snip>
Cool, I had the same or a very similar machine once. Mine had a 486 DX-33 and 8MB ram.
1982 to 2001
Reply 24225 of 60068, by luckybob
Vegge wrote:
*snip* And this beast arrived today 😎 Looking forward to playing with it 😀
[image of dual cpu tyan board]
omg I have one of those boards, wont post. I think it's a bios error. Would you be so kind as to dump that bios for me? I'd be very grateful.
Reply 24226 of 60068, by OldCat
Wait, it had AWE64 by default, as part of regular setup? Also - how big is the screen and how much does it weigh? Could you do some more photos, preferably in action?
(I like how it's your hand and a row of other machines reflected on the dark screen)
Reply 24227 of 60068, by Eleanor1967
LGR made a Video where he uses a PC like that:
https://www.youtube.com/watch?v=qex_6pWzuog&t=1s
I think he also made a video on the PC itself, don't know that one though.
Reply 24228 of 60068, by LeFlash
Ozzuneoj wrote:
Awesome stuff. Can you list the equipment you use? Get as detailed as you like.
Basically a cheap SMD reworkstation with separate small soldering iron from ebay will do the trick. Sub 100$ range.
Some good flux (i used amtec), very small solder wire.
For diagnosis a oscilloscope and multimeter won't hurt.
I learned a lot about BGA from Louis Rosmann (Youtube channel) where he is raging about apple while repairing their products. 😉
Steps:
- Find fault
- Get replacement
- mask everything with aluminum foil so other parts don't get too hot
- use capton-tape (heat resistent)
- use good amount of flux on the pins
- use some air filter or cheap fan with carbon filter (flux is not healthy)
- heat the part evenly, at some point you can just pick it up
- clean the pads with flux and wick
- on newer boards with Pb-free soldering, use leaded solder first to get rid of the Pb-free one
- clean with alcohol
- place new part
- tack 2 diagonal pins
- solder pin-by-pin OR
- solder everything, flux it and remove excessive solder afterwards
- clean flux residues
Most of this stuff can be seen from videos.
Reply 24229 of 60068, by root42
LeFlash wrote:
Basically a cheap SMD reworkstation with separate small soldering iron from ebay will do the trick. Sub 100$ range. Some good fl […]
Steps:
- Find fault
- Get replacement
- place new part
In theory I know all this, but it takes a lot of practice to get it right! I have tried to solder the XT CF Lite, and while it does work as a BIOS card, the CF adaptor seems wonky. The stupid little SMD fins ALWAYS suck up the solder in between them, no matter how much flux I apply...
YouTube and Bonus
Reply 24230 of 60068, by xjas
Technically I didn't buy this - it was given to me - and it wasn't today, but I finally got around to digging it out and bringing it home - a handy compact HP tower:
The attachment 1.jpg is no longer available
Nothing too special, it's an Athlon 64 x2 4400+ with 3GB DDR2 on an nForce chipset (Geforce 6150SE onboard.) Exactly at the bottom of its depreciation curve, even in this town where everything is five years behind the rest of the world, so the price was right. 😜 Still useful for my needs.
It was dusty as hell but a date with the vacuum cleaned it up nicely.
This thing will run my twin Datapath VisionRGB cards as I need them in a 'small' machine I can pick up and lug around.
The attachment 2.jpg is no longer available
It came with a second network card and 56k modem occupying its two PCI slots, but I took those out already.
The attachment 3.jpg is no longer available
^^ does this look wrong to you? It does to me! (it's BTX. 😜 )
The attachment 4.jpg is no longer available
Lots of storage & media options up front. I don't have anything for that 'HP Pocket Media Drive Bay' (did you really need five words to describe that, HP??), which takes a custom removable enclosure for a laptop-size SATA or IDE drive. I could see that being handy.
The most interesting thing up there is a lightscribe CD/DVD burner, which was a really neat take on labelling CDs that didn't catch on. Never had one before so it'll be a fun thing to have a go at.
Lightscribe discs seem to be far harder to find than the actual drives these days - fortunately, I lucked into a spindle of them for a couple bucks recently (and some mini CD-Rs for good measure) :
The attachment 5.jpg is no longer available
Not sure what I'll do with these, maybe I'll release a special "gold" limited edition of my upcoming EP or my game on them. Only nine copies!
Reply 24231 of 60068, by Cyrix200+
Steps:
- Find fault
- Get replacement
- place new part
I am pretty good at regular soldering, I have had no need to do this yet. But I kind of look forward to doing it 😀 I will need some practice though. And that cold beer for a steadier hand.
The attachment d6d.jpg is no longer available
1982 to 2001
Reply 24232 of 60068, by SW-SSG
I assure you it is actually standard Micro ATX. Any mATX board should fit the mounting holes and expansion slot bracket. HP just had a weird attachment with its upside-down mini-tower cases during this period.
Reply 24233 of 60068, by bjwil1991
I believe Dell was like that as well for the BTX systems, such as the Dimension E510 which is impossible to install an mATX board in there since the I/O ports are right-side up.
Reply 24234 of 60068, by xjas
^^ haha on second look you guys are right, it's not BTX. The "wrong" side of the case opens up & the board's in there upside-down. Guess I'm a bit dyslexic. 😜 I wonder WTF they did that for? I'm not planning to swap it out so no problem.
Reply 24235 of 60068, by badmojo
gdjacobs wrote:
Was Sonic really that great on the Master System? It was sure the bees knees on the Genesis, but I don't remember seeing it on the older platform.
Sonic was great on the SMS, better than he Genesis version I think. Great level design and it still plays V fast.
Reply 24236 of 60068, by keropi
^ it was a feat allright to fit Sonic in an 8bit console but it was not better - naturally because of technical limitations. The 8bit version is a great platformer but in the end it was different than what the genesis version was - level design included so it suited the system. Was it a good choice back then? Yeah because that was SEGA's new mascot and the system needed a refresh you can't bundle the same game for ever 😁
Damnit now I got to hook the sms and play it 🤣
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 24237 of 60068, by candle_86
$30 working x1950pro AGP
The attachment 20180709_201611.jpg is no longer available
I think I'll upgrade my 6600 256mb on my a64 3400
Reply 24238 of 60068, by Murugan
1) boxed Sapphire 3870 (not that retro and didn't take a pic sorry)
2) a pile of optical drives. I will need to test them.
3) These 3 boys
They are 2x 386SX + Coprocessor and the other one turns out to be a 8088 yuy.
If anyone can help me identifying the motherboard, feel free 😀
Reply 24239 of 60068, by Intel486dx33
More stuff
