First post, by aries-mu
Guys, does a 486 motherboard exist that is able to set a FSB to CPU multiplier to 2.5?
We'd have our unicorn 486 CPU!!!!
• Take an Enhanced AM486 DX4-120 Write Back
• Set the FSB at 50 MHz instead of 40 MHz
• Push the PCI at 50 MHz if possible (I know I know...) otherwise set the PCI at 2/3 so that it runs exactly at 33 MHz (instead of the unfair 27 MHz if the FSB runs at 40 MHz)
• Set the FSB to CPU multiplier at 2.5, so that the CPU runs basically non-overclocked at 125 MHz (come on, from 120 to 125 even I wouldn't consider that overclocked, and I HATE CPU overclocking)
• FPM or maybe even EDO 60 ns RAM and WB L2 double-banked Cache running at 50 MHz?
feipoa, what do you think?
Thanks!
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
