Tetrium wrote:gbeirn wrote:Here is my current work area at home in my garage: […]
-snip-
I recently bought an Ultrasonic Cleaner and cleaning solution and used it to revive a water damaged iPhone, I've tried it on a few dead board that have had battery leakage and I'm impressed with the results so far.
![w0CBTLE.jpg](https://i.imgur.com/w0CBTLE.jpg)
That's an impressive setup!
Could you please tell me more about your experiences with the ultrasonic cleaner?
Sure! I originally bought it because my nephew dropped his iPhone in a river! when we were camping. Phone shorted out and would't turn back on. Once we got home a few days later I disassembled it and there was water all over the main board along with minor corrosion beginning. I was familiar with the idea of repairing water damage with ultrasonic cleaning so I did some research and bought the cleaner you see in the picture. I also bought the cleaner you see as well since phone repair people said nothing is better.
Once everything came I used the heat gun to remove the metal EMI shielding on the iPhone board and noticed water/ionization stains on the chips. Looking at it under a microscope showed blackened solder points where capacitors were and a fine 'mold like' substance whisking away from components. I assume this is the corrosion between parts due to the electricity flowing through the ions in the water.
The ultrasonic cleaner you see in the photos is 6L - way too big for phones. The company is called Vevor - out of china and they have several different sizes. I might purchase a 0.3L size for phone boards and other small electronics.
Anyways, I fill it up with distilled (soft) water bought from the grocery store. Carefully measuring the amount of water. I think I used about 4.5L. The cleaning solution is a type of ammonia with various surfactants. The bottle recommends using in a concentration of 3-5%. I believe I used 5%. The ultrasonic machine also has a heater so I heated the unit up to 54C, mixed the cleaner and then was ready to go.
Use caution with the concentrated cleaner, it is super caustic, the MDS lists a pH of like 13 or 14. Quite a strong odor. I used gloves and a large open area when mixing it. It's also not cheap. That bottle ran about $40 shipped since it has to be shipped carefully due to it's caustic and corrosive nature. Since you dilute it %-wise a smaller ultrasonic machine for smaller parts will pay for it's self with saved cleaner and water.
I suspended the iPhone board in the unit, set the timer for 3 minutes and turned it on.
I wish I filmed it. The board looked mostly clean to the naked eye, only seeing the damage under the microscope. When I turned that machine on however - poof. It looks like clouds of dust were coming off the board under the water - all the microscopic corrosion.
I ran it for 3 min, flipped it and ran for 3 again. After it was done I carefully removed it using plastic tweezers and washed it under 91% isopropyl alcohol. Once that was done I ran it under the heat gun until it was dry.
Brought it back inside the house, hooked it up to the iPhone battery and screen, tried turning it on and....
it powered right up! I did a little dance and spent the next hour replacing all the little screws and putting it all back together. Gave it a full charge and it's been working great so far (about 3 weeks now).
So my opinions for using it for something like that - amazing!
I have also tried it for computer parts:
I recently had a shipment of computer scrap that included 3-4 dead 486 motherboards. All had leaked batteries but all had likely other issues as well ( No POST codes, beeps, etc.)
I took 3 of them and cleaned them the same way. Removed the dead CMOS batteries, removed any removable ICs - CPU, cache, BIOS, KB controllers, etc.
I heated up the ultrasonic cleaner, added the solution and cleaned each board for 3min 4 times. I could only submerge about 1/3 of a baby AT board so I ran it for 3min, rotated the board 90 degrees, and repeated until the board was done 4 times.
Now this didn't magically fix the boards like the phone. The phone had been only a week at most, not years and also had been water corrosion not batteries. However the boards are now spotless! The hardest part for cleaning a leaked battery is usually the corrosion under sockets, in slots that kind of stuff. Super clean now. Since we are fully submerging the board and the ultrasonic action is designed to clean hard to clean things I can picture this saving tons of hours not having to de-solder, clean, replace parts.
After running 3 boards through the machine, the water looked cloudy with 'clumps' of the corrosion it cleaned off.
Before I'd recommend running out and buying one, I'd like to try it on a known working board that maybe needs a clean up just to make sure it doesn't damage anything. Hard to tell when my test subjects were already kaput. I'd imagine if a iPhone mainboard survived a 30 year old board that is built way stronger would be fine.
I have some before pictures, when I get some time, I'll take some after to compare.
George
