First post, by walterg74
Hi all,
I was looking for a Pentium II 450, and a fellow member of a facebook group offered me one.
I purchased it, and I received it today. However, when I look at the case the lettering says: pentium III... 😲
I asked the seller about it, and he says he tested it before sending to make sure, and it boots up as a PII as yu can see in the attachments.
Does anyone know what’s going on/how this could be..?
399.8 KiB
85.71 KiB
Reply 2 of 17, by darry
Try running CPU-Z or another such utility. The casing on the CPU may have been exchanged or the BIOS might be misdetecting, but the CPUID as detected by software should be reliable.
Reply 5 of 17, by dionb
Why? A P3-450 will work at least as well as a P2-450 in absolutely everything. Only difference is the SSE1 instructions, which are an improvement (if almost never used by period software). I have both and the only difference I notice is the cooler (the P2 has a huge passive heatsink, the P3 a noisy little fan).
Reply 6 of 17, by Katmai500
The most recent BIOS update for the RC440BX board is from 2000: https://downloadcenter.intel.com/download/914 … -?product=50524
There's a chance you could update the BIOS to recognize the PIII before returning it.
Reply 7 of 17, by walterg74
Ok, I could do that. But that still will not change the fact I wanted the 450 PII and this is a PIII? 😀
Reply 8 of 17, by walterg74
Imguess just because Imwanted to build one of each PI, PII, PIII machines with the actual processors
Reply 9 of 17, by Errius
I think Katmais run hotter than Deschutes of the same frequency?
I have a 550 MHz PIII which is a little furnace. I had to remove it from one of my builds because of the heat.
Is this too much voodoo?
Reply 10 of 17, by BinaryDemon
Hah. I understand the desire to be period correct, but even the bios sees it as P2. I'd call it good enough. 😀
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 11 of 17, by PARKE
You could try this:
For Intel® Processor Frequency ID Utility
Intel® Processor Frequency ID Utility Bootable version [BFID_X25.EXE]
Version: 7.2 (Latest) Date: 11/15/2004
https://downloadcenter.intel.com/download/308 … XE-?product=672
The PII "should" be identified as Family 6 / Model 5 and the Pentium III as Family 6 / Model 7
Reply 12 of 17, by walterg74
Yes, but *I’d* know... 😁 😁 😁 😁 😁
Reply 15 of 17, by stamasd
oeuvre wrote:
tomato/tomato
I thought that was not a slot 1 motherboard.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 17 of 17, by lordmogul
Could also remove the shroud and look at the chip directly. They got a print of the batch number that you can trace back
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
