Reply 25100 of 58769, by Thermalwrong
yawetaG wrote:
Slightly more than a DB50XG/DB60XG in a box, because with certain editors you can do more with it than with some of the other MU-units as certain parameters can be modified more extensively than on later MU-units.
That's excellent, I wasn't aware of that, I'll have to look into it although I wonder if it's a bit wasted on me in that case?
dionb wrote:
Case in point: my idiot Packard Bell system, with MS-6168 (yep, you triggered me 😉 ), active fan on the Voodoo replaced by a big-ish passive heatsink, CPU fan replaced by a Zalman CNPS6000, Zalman's original small 80mm fan replaced by a 120mm Noctua, and the 80mm in the PSU also replaced by a quiet Noctua 80mm. Oh, and an SSD instead of a HDD. So now it's almost silent - except for some coil whine I couldn't hear before 🙁
Nice find. That looks like the rev.1.0 with i440ZX chipset. The power regulation circuitry is different to the rev.2.0, which is bad news if you want to run a Coppermine (at least in theory), but good news that they didn't use the suicidal caps on the rev.2.0. Your pic isn't good enough to be completely sure, but it looks a lot better than my two rev.2.0 boards did when I got them.
Interested to hear if you could get a Coppermine running on this baby.
Yep it's a v1.0 from the pictures I've seen so far - somehow i keep ending up with the 440ZX chipset instead of the BX 😀 That's useful to know that it might not be so good even with the coppermine - I've wanted to have a play with this board since I spotted it for sale (and missed it) for £10 back in around 2002 so even if I can't do much with it, it should be fun. I've been a little jealous of all the ones you've found, but thankfully persistence keeps paying off 😁
Reply 25101 of 58769, by yawetaG
It's basically a halved, headless Yamaha QS-300 synth without the sequencer and other fancy bits. If you ever wanted to get into music creation, this is a nice (cheap and overlooked) module to start with.
And it will do GM/XG, of course. 😀
Its CPU was later used in Yamaha's CS-1x synthesizer, AFAIK.
Reply 25102 of 58769, by Viper87
Hi
Its my first post and i wanted to share with you my recent purchase:
Most of them have damaged pins but i think it can be fixed.
It cost me 51 PLN ~14USD
Reply 25103 of 58769, by Tetrium
Intel486dx33 wrote:
Compaq sound card - 1994 ( ISA ) - ESS 688F with Yamaha YMF-262 OPL
I don't know if I should change the mounting bracket or leave it alone.
What computer do you think this came out of ?
I once salvaged such a sound card from some Compaq. The extra connector bit is very distinctive. Iirc I did search for info on that card and iirc again, it should work without those connectors attached to something? They were for the internal speaker or something, can't remember.
Regarding the bracket: I'd say, if it fits, keep it on the original card 😀
jesolo wrote:
Srandista wrote:
kixs wrote:
It's a very nice card! You didn't pay too much for it but shipping from NL is always too expensive...
Stalker! Yeah, what you can do. It's always strange, when you pay more for a shipping then for a product itself...
Reminds me when I bought an item back in 2005.
Paid $10 for the item and $40 for shipping.
I at one time bought like 8 of the backpack external floppy drives. The drives themselves were $1 each or something. Shipping was more like €70(??) or so...darn 🤣!
The seller had a large stock of these and these were brand new. To keep shipping costs down I had them send without the boxes though. Very neat things, I have no regrets 😎
cyclone3d wrote:
Intel486dx33 wrote:
Artex wrote:
@Intel486dx33
Cool stuff, but maybe try to consolidate into a single post? 😀
I don't recieve everything at once.
I will try to limit my post to once a day in this topic.
Each post will only allow 5 pics if you upload them to the forum. Sometimes it can't be helped.
You can however use paint to put several pics together so the total number of pics becomes 5 or less 😜
edit: I meant the program Paint and not the wetty stuff that you put onto solid dry surfaces 🤣
My retro rigs (old topic)
Report spammers here!
Reply 25104 of 58769, by appiah4
Gigabyte_GA-_BX2000_B_Damaged.jpg Intel_Pentium_III_600.jpg Creative_Audio_PCI_CT4810.jpg
The BX2000+ board has some swollen caps and a broken Bank 0 simm slot, but POSTs so I just listed it locally for sale for anyone who will bother to fix it. I already have one in stock (that I partially recapped) so I can't be bothered.
Got all of these for an amazing $1, and the shipping cost was $3 so I am not complaining.
Reply 25105 of 58769, by Intel486dx33
Two Sound Blaster AWE64's
Reply 25106 of 58769, by dionb
Post from the USA today:
Aztech NX Pro, an old Soundblaster Pro 2.0 clone (with real OPL3) with a twist: it also supports Covox & Disney Sound Source. If this thing works and I'm happy with it, it's going into my ultimate soundcard build, alongside an SB32 (for SB16 support) and a GUS - and maybe a MusicQuest if I can get it all to play together nicely and I have enough ISA slots.
Also made a pic of yesterday's free IBM PC330-P75 pickup. Apart from a dead CMOS battery (relieved to see it's a CR2032) it works perfectly. PIctured with my Lexmark-made 1994 vintage Model M, which is not exactly period correct, but doesn't look too out-of-place.
Reply 25107 of 58769, by bjwil1991
I have an exact card like that as well. I repaired it a few times, but, it still works. Having the Covox Speech Thing and Disney Sound Source with a genuine OPL3 chip is the icing on the cake.
Reply 25108 of 58769, by dionb
What did you need to fix on it?
I read that it tends to sound pretty noisy as it lacks shielding, so it should be put in the last ISA slot or have a metal plate mounted in front of the solder side. You do any of that stuff while you were at it?
Reply 25109 of 58769, by bjwil1991
Yes. I had to fix the traces for the volume pot to the caps, the mic in and line in jacks since the traces got destroyed by me. Luckily, I had some wiring, solder, flux, and knew where the traces lead to.
Reply 25110 of 58769, by arncht
i could buy a new antec p180 for 85 eur for my 2006 rig... is it worth the price? from retro aspect, it is too much, but i dont think, i will have any chance in the future to buy a new one.
Overdoze of the demoscene
Reply 25111 of 58769, by vmunix
What other Turtle B. cards do you have ?
Trailing edge computing.
Reply 25112 of 58769, by vmunix
keropi wrote:
:D after many years I got a SW-60XG again […]
😁 after many years I got a SW-60XG again
I've got that thing and the manual but no CD, what's in there ? any interesting soft to control the synth sounds, like editing or something ?
Reply 25113 of 58769, by cyclone3d
Oh yeah, we want an image of that CD!
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 25114 of 58769, by vmunix
Manual
mm94ftw2Dkv_xAaM9xxgd00pXEpawFe_lRIkhzjWYWrKsJCogG7eGxBz9es5PAIj_gPJzeQ_A5R7hwVYQftz6FoC4C9XLhpyTHrUTCM49CwJlHM2WmTNlvF9qGUqNJR4dnwrcxXM9GgcbvZJNsZJpKAcBaFKxEkl74c67MflPusdL6I5kV4GM-2ztxXrdnsHB_xltM6aGPZjj65lVGe9nHxT0nVyodrpOxzDwBirqMDyHi-OEQR9jVsrKI_klIqWLPsyj7rJYHHzUA2Adn0F9xUVrl9i0BsB7dJ-zICM75ItBVp0WlHAHkLxJbP84kIsG_yWarSGSrJBYLp3HYdKu8lrE3hOz2p_jzY4fhfj9z6v8fBQWhP9AZav84yA_P9Gl8E8CNdgODDT7ufphslM6Y7fUIpr_TflZ1oPb4WLa0LOl3tRCRSdsiGfaHRKnxtNnlgmjVO7zFNsU9ORCigeeXq3f91BvFvlNUn-dW_N6psiQHu137V2YtlC4JNrf70esliEnzqkiAvtAH2DrFDob5nlDkKufQuqlOT-eoItKUzSD76IWiBu8K5Jl0Kk4ycjYV7nh9Tk9mo9IOtLdfVtBfwyZG8PfjL0DElsSBmSGJGEck86p3LWx-C2ANboHw1C=w552-h981-no
Reply 25115 of 58769, by luckybob
Thrift Store haul!
L->R
Samsung CLP-325W Color laser printer - works! Was $15! Only 2654 pages printed!
Zany effects! - plug into your landline to insert sound effects! $1
Western digital 1TB nas (feels like drives are inside) $17
Neon Floppy disks! $2
Creative SBS10 speakers! $2
Spaceballs! The video Cassette! $0.50
Sub command! - $2.50
Some NIB PRO Movie Spectrum thing - $2.50
Pair of Advent Speakers. $18/pair
Gonna play with the 1tb nas right now to see if she works.
Reply 25116 of 58769, by liqmat
luckybob wrote:
Thrift Store haul! […]
Thrift Store haul!
L->R
Obviously the gem in that crowd is SPACEBALLS!!!
...and the sealed capture card which was $400 when it was new in 1992.
Reply 25118 of 58769, by luckybob
fyi, i see it okay.
Reply 25119 of 58769, by Stiletto
luckybob wrote:
fyi, i see it okay.
Your image is fine. vmunix's is not (Firefox 56/Firefox 63/Chrome 69). But I assume you actually DID mean vmunix.
I bet if you cleared your cache and refreshed the page you wouldn't see it anymore, luckybob?
Still, I can pretty much guarantee if he follows my procedures that both you AND I would be able to see it, along with everyone else.
do the Fandango!" - Queen
Stiletto
