First post, by Arson
Okay. So. While i opened up my T4900CT, i noticed corrosion on the backup battery. I disconnected it, cleaned off the leakage and took a closer look. It definitely had leaked or exploded sometime in the past. Now, after some google digging and head scratching, I have come to the forums to ask for another set of eyes!
As you can see, there was significant leakage from both the positive and negative sides of the battery.
I have browsed around ebay and with several battery sites but have not been able to locate a replacement.
I have also not been able to find a replacement for the CMO battery labeled, "Toshiba VG2430". It is a 3v Lithium button battery. Unintentionally, I also may have accidentally ripped the Zif cable when i was dismantling the laptop. So I will need to find a replacement for that as well.
Reply 1 of 3, by cyclone3d
The battery pack shouldn't have to be exact. Closest I am seeing is a 40mah which should work just fine:
https://www.ebay.com/sch/i.html?_from=R40&_tr … &LH_TitleDesc=0
And the 3v rechargeable should be able to be replaced by this. You will just have to either wire it up or get a holder:
https://www.ebay.com/itm/2PCS-New-Original-3V … epid=1956570815
Good luck with the ribbon cable.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 3, by Arson
cyclone3d wrote:
The ba--
Thanks! I appreciate the assist! You sure about the 3v type?
