First post, by Samir.Habib
Hello everyone, I wrote about this build specs in " Anything else besides games on your retro PC? How old are You? ". I have troubles with it, wich i have never faced before. Here's the hardware.
Motherboard ASUS P/I-P55TP4XE with 256K Cache
4 sticks of 8mb ram
Pentium-S 133
256 kb Cache module
Matrox Millennium 4mb
Creative Sound Blaster AWE32 CT3990
Everethyng works fine in Win95 RTM, except floppy. It shown like 5,25 in the system. In bios in's setup as 3,5. Even after chipset 430FX driver, the same thing. But i wan't DOS 6.22 run on it. And whet HDD is formated, floppy installs DOS fine. After it installed, i can't install anything on DOS.
CD driver, Wolfinstein 3D, Win 3.11.... It gives me "sector not found reading drive a".
Don't know what to do whith this!!!!! Please HELP. I WANT DOS 6.22 + WIN 3.11 machine with CD ROM.
    778.33 KiB
    718 KiB
    678.76 KiB
    1.45 MiB
Reply 1 of 11, by weldum
check with another floppy drive
disable the floppy controller under bios and use an isa i/o card for testing
change the floppy cable, it may be faulty
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 4 of 11, by appiah4
Samir.Habib wrote:
i will try with another cable, but i don't have isa i/o card.... Also floppy is GOTEK Emulator, and it's works fine with 440BX motherboards (ASUS P2B & P3BF)
What firmware are you using with the Gotek emulator?
Reply 7 of 11, by appiah4
Samir.Habib wrote:
USB_Floppy_Manager_v140i
Please format your firmware to either FlashFloppy or HxC the default firmware is unreliable at best. I would not trust using it with this firmware to determine whether the hardware is faulty. Do you have any real floppy drives to test with?
Reply 8 of 11, by Samir.Habib
I'll try another software. unfortunately i don't have any floppy diskettes for real floppys.
Reply 9 of 11, by Samir.Habib
I don't know.... I mus put my self there where i shuold't be. This motherboard worlks only in Windows 95 (RTM), of course other versions of it, and 98 and SE and ME, but god goddamned not only in dos 6.22. Software doesn't solves the problem. Gotek works on other boards.
Reply 10 of 11, by Samir.Habib
Excuse me, but i don't understand how to work with this software (FlashFloppy or HxC)
Reply 11 of 11, by Samir.Habib
I found here on VOGONS the same topic 1.44 floppy problem in DOS 6.22. 1.44 floppy problem in DOS 6.22
Member call it self Cadderlik solved this problem by changing Dallas batery, to another. So in my case, should i just rework my Dallas by adding fresh CR2032 battery, or i should by the whole new Dallas from eBay. I'v heard that a lot of them D.O.A.
    13.94 KiB
