First post, by Paralel
Which version of the SB16 is the best to pair with an SCB-55?
Must not have the hanging MIDI bug, also must not muffle MIDI daughterboards. The less noise the better. Must be Non-PNP or just require the simple SYS driver in Config.sys. Must be ISA. Must either have a discrete OPL3 chip (which is preferable) or the 1747 chip that has the OPL3 integrated core.
