First post, by 386SX
I got for cheap a Pentium G2130 on Socket 1155 and a Asrock H61M mobo that had problems and probably not working but I found that many pins on the socket has been pressed and had to be fixed. I was surprised to see that now the board is perfectly working with this cpu. 😀
I've seen that the motherboard supports 2nd and 3rd generations of i3/5/7 processor but I don't really know much about them, can you give me some info? Are they good or not, any info of which processor not too expensive I could buy?
Also I'm testing this low power G2130 cpu and impressed to see that is working with 40W or less watts. Was it a good even if low end cpu?
Thank
