First post, by McBierle
Hi, i got this board from my collegue.
Aside from some batterydamage one of those resistor networks was cracked (in half). It is already desoldered and i measured 10ohms. Just for my curiosity, i couldn't find any "SMT B 100G" with uncle google, does anyone know why? Shouldn't 10ohm be "...103..."?
143.52 KiB
This "BC17" smd capacitor was smashed. Is there any way to know what i should get, short of desoldering BC18, getting the tool to measure caps and hoping its the same?
652.26 KiB
I also found the damage in the next two pics. At least 5 lines are totally broken. I'm hoping to just use wire to bridge those cracks.
843.24 KiB
887.12 KiB
Greetings!
Reply 1 of 2, by quicknick
100=10ohms, 103=10kohms
"B" could mean "B-type circuit", see penultimate post from here. But you must double-check with your multimeter, because "B-type" is rather uncommon, or at least I haven't seen it used on such a large scale. For the rest of the damages, thin wire, lots of flux, patience and good eyes 😀
Reply 2 of 2, by Tiido
If they are the B type that means there's 4x 100ohm resistors in them and they're used for signal filtering purposes. It seems that probably is the case since I see enough arrays for 32bits. You can substitute things with 4x 100ohm resistors in place of the array.
As far as the capacitor goes, it is most likely a 0.1µF part. Its presence will likely not make any difference except at perhaps when pushing timing limits.
