Best Socket A (462) Motherboard?
Reply 200 of 223, by undeon
I'm planning to get a Corsair VS400 (5V@17A and 12V@32A, single rail)...
Reply 201 of 223, by appiah4
alvaro84 wrote:
appiah4 wrote:
20A 5V won't cut it.
Wait. The AN7 does have an ATX12V connector. It must diminish the need of a beefy 5V PSU.
I believe this was tested at some point and people found 12V connectors on Socket A motherboards did not really help much with 5V power draw? I may be misremembering though..
Reply 202 of 223, by The Serpent Rider
Nemo1985 wrote:
decided to buy a Gigabyte ga-7vt880-l, because seemd like the asus but with 4 pin connector. Too bad I just found it doesn't support the pci and agp fix
Let's be realistic here. Most likely you won't push it far beyond official 200mhz bus (there are PCI/AGP dividers for that) - 220 at best. You don't need fixed AGP/PCI clock for that.
Nemo1985 wrote:
a good price a Epox EP-8VTAI, it has pci\agp fix, it's very overclocking friendly and so on, but just 2 ddr memory slot
Why would you need more? That's enough for 2 gigs of RAM, which is an overkill for any Athlon XP system.
Reply 203 of 223, by appiah4
Here's a list of the 462 boards I have.. out of curiosity, are these good boards?
Gigabyte GA-7ZX
Gigabyte K7 Triton
ABIT AN7 Guru
Reply 204 of 223, by Nemo1985
The Serpent Rider wrote:
Let's be realistic here. Most likely you won't push it far beyond official 200mhz bus (there are PCI/AGP dividers for that) - 220 at best. You don't need fixed AGP/PCI clock for that..
With older Athlon cpu with lower fsb I can't overclock the bus anyway... so it would have been nice to have them.
You are right.
Reply 205 of 223, by doaks80
KT333 chipset with 3.3v AGP so you can run a voodoo in there. MSI models like KT3 Ultra are fairly common and affordable. Note not every board with universal AGP slot actually supports 3.3v so be careful.
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
Reply 206 of 223, by undeon
I'm planning using a Radeon Hd4650... From what I found, most of the problems everyone had was using GeForce 3/4 and Radeon 9000 series. These cards uses 5V.
Anyway... The first test I'll do will be with a Aerocool GT 500SG (500W, 22A 5V)... I'm looking for a Corsair CX450 (20A 5V, new, very pricey) or an Antec PP-412X from 2001 (400W, 40A 5V 🤣). The problem with Antec is its age... 17 years already...
Reply 207 of 223, by Munx
It depends on the motherboard, however there are plenty of SA motherboards that run the CPU from the 12V rail.
My builds!
The Underdog - The budget K6
Reply 208 of 223, by undeon
Did you know something about the Abit AN7? Thanks 😀
Reply 209 of 223, by Nemo1985
I finally had time to test the Msi Kt3 ultra (with a 3000+ and radeon 9600 xt), but a weird thing happened.
I tried to use the PSU with highest 5v ampere.
I have those:
Tagan 580w
3.3V 26a 85.8 watt
5V 30a 150 watt
max combined power 180w
Tecnoware 550w
3.3V 24a 79.2 watt
5V 24a 120 watt
Seasonic 300w
3.3V 28a 92,4 watt
5V 30a 150 watt
max combined power 180w (40a)
I tried the Seasonic 300w (SS-300GS) but a weird thing happened, after 2 seconds and without anything on screen the system was shutting down by himself.
So I tried the Seasonic and it worked like a charme.
Maybe 300 watt is not enough?
I know that all of them are suboptimal since they are newer but I've haven't been able to find anything older...
Reply 210 of 223, by gdjacobs
Check caps.
Reply 211 of 223, by Nemo1985
gdjacobs wrote:
Check caps.
Caps are perfect the issue could be the seasonic (but it works fine in a p4 rig)...
Reply 212 of 223, by brostenen
gdjacobs wrote:
Check caps.
True that ALWAYS on 00/05 hardware, and especially SocketA.
Reply 213 of 223, by gdjacobs
Nemo1985 wrote:
gdjacobs wrote:
Check caps.
Check caps on the PSU as well, especially output filter caps. The P4 rig doesn't put much load on the +5V rail, so it's a very different testing condition.
The Athlon should be well within the capabilities of the Seasonic. It's under performing for a reason.
Reply 214 of 223, by canthearu
While this may not be the "Best" socket A motherboard, this is still a decent board. Now restored with new polymer and electrolytic capacitors, hopefully this restored board will go on for a good long time!
Reply 215 of 223, by The Serpent Rider
Should be also noted, that many late motherboards like Abit AN7 or ASUS A7N8X does not have thermal diode to monitor Athlon Thunderbird temperature.
Reply 216 of 223, by alvaro84
It's indeed an important point: the best board is a working board.
I also agree with the other half: it's really not the ideal board, at least not for me. It's an oldschool SDRAM piece yet it doesn't have an ISA slot.
I have, on one side, the Abit NF7-S with ATX12V power and 400FSB with DDR, and the Abit KT7A on the other, which has an ISA slot and works well with DOS sound cards - but with performance bottlenecks from the limited FSB and the SDRAM.
The best (for me) would be a unicorn with both: high performance and extended CPU support from high FSB and DDR memory - and at least one ISA slot. But I'm fine with these two options too.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 217 of 223, by appiah4
I'm still looking out for a KT333 board; I'm all set for KT133+ISA and NF2+Dual-DDR, now I need Universal AGP + DDR..
Reply 218 of 223, by The Serpent Rider
There's plenty of that junk lying around, Perhaps not many cream of the crop boards, but enough decent ones.
Reply 219 of 223, by appiah4
All I come across here are KT400 and NF2 with the occasional KT600 in there, KT333 and KT133 are rather obacure..
