First post, by Baoran
I'm bit worried about how to make it work without overheating the voodoo 2 cards.
Situation would pretty much be this in a tower case.
ISA sound card at the bottom of the case for dos (only ISA slot on the motherboard)
Empty pci slot above the ISA sound card.
Voodoo 2 card above that empty slot.
PCI sound card for windows above the voodoo 2 card. (not installed yet)
Another Voodoo 2 card above the PCI sound card.
2 Slot video card at the top in the AGP slot. (hasn't arrived yet so I have temporary single slot passively cooled card currently in the agp slot)
Cooling?
The psu at the top of the case seems to sucking bit of air from the outside to the inside the case...
I ordered 2 good fans for the case 92mm fan for the back of the case above the cards that I would put suck hot air from inside the case to outside and 80mm case that would suck air to inside the case at the front of the case. These fans have not arrived yet but should come within next week.
Is this enough cooling for the voodoo 2 cards? I feel like they will be tightly packet inside the case when I put the PCI sound card in between them.
Is there anything I can do to improve the situation?
