First post, by dionb
I'm stuck with an old 40MB HDD. It spins up, it talks to the IDE controller on my Rectron RT-4S3 late 486 motherboard - but I can't find any C/H/S settings that will do anything.
Here is IBM's own information on it:
http://ps-2.kev009.com/ohlandl/IBM_HD/WDA-L4x.pdf
That suggests I should use 1067 Cylinders, 2 Heads and 39 Sectors. That gives a nice plausible 42MB size. Fdisk (MSDOS 6.22) detects the drive and lists no partitions, and when I try to make some, after a reboot they are gone. I have the distinct feeling I'm hitting a 1024 cylinder BIOS limit, which I should be able to work around via geometry translation - but I can't for the life of me find anything.
I tried halving/doubling the cylinders/heads, so 533 / 4 / 39, but same result.
The only other resource I could find was this:
http://computermuseum.informatik.uni-stuttgar … /ASCII/1720.TXT
                                                       Native³  Translation
ÄÄÄÄÄÄÅÄÄÄÄÄÂÄÄÄÄÄÂÄÄÄÄÄ
Form 3.5"/HH Cylinders 1067³ ³ ³
Capacity form/unform 40/ MB Heads 2³ ³ ³
Seek time í / track / ms Sector/track 39³ ³ ³
Controller IDE / AT Precompensation
Cache/Buffer KB Landing Zone
Data transfer rate MB/S int Bytes/Sector 512
MB/S ext
So no translation, but >1024 cylinders...
For what it's worth I also tried IDE autodetection. It clearly doesn't detect correctly, but the fact I get anything back at all tells me the drive should be alive. Here's what 'auto' gave:
C 15277 H 5 S 17 (=664MB) in Normal mode
C 7638 H 10 S 17 (=664MB) in Large mode
Anyone have any suggestions?
Reply 1 of 3, by brostenen
My best advice, is to plug it in a motherboard that can do HDD autodetection and see what it finds. A Pentium socket7 motherboard should do the trick. Or something like a Slot1/A/Socket370.
Reply 2 of 3, by dionb
Er...
Reply 3 of 3, by brostenen
Sorry... Did not read it completely through. My mistake.
