I have 3 main retro PCs:
1) P200MMX MS-DOS PC (used often)
2) P2-400 Win98 with V2 SLI and SB16 (used rarely)
3) P3-933 WinME with GF3 Ti200 and SB Audigy (used rarely)
Months ago, the proprietary PSU in the P2-400 went bad and I didn't have the money or motivation to replace/fix it since I used the system so seldom. So finally, I got around to transferring the pair of Voodoo2's into the P3-933. I set up my older games (MotoRacer, Quake II, Unreal, Half-Life, Thief, MDK, etc) to use the V2 SLI while the newer games (Unreal 2, RtCW, Deus Ex, Undying, Jedi Knight II, etc) use the GF3. Aaaaannnd, the system still gets used rarely, but at least I can run games on the Voodoo2s again if I get an itch. As some of you know, I mostly use my retro systems to play through the best FPS and RPG games of yesteryear, and I do have a few games on this system on my To Play list, so eventually I will get a lot of use out of this system again. 😀
