Help to identify a 286 Mobo
First post, by muon
The motherboard is this:
I've looking for in the typical websites and I haven't found nothing about that mobo. I would like to upgrade the memory. It has 512kb of memory.
Best regards
Reply 1 of 25, by Predator99
Before doing anything else you shoudl remove the battery 😉
Maybe you are able to upgrade to 640k by adding an identical chip to the empty socket on the bottom left.
But you should be able to add an additional 4MB with 4 SIPP-modules. Maybe there is a jumper to switch between banks, just try all of them 😉
Reply 3 of 25, by root42
I second the battery removal. Also, good chance that it will auto detect the RAM in the SIPP sockets. Stason TULARC didn‘t have this specific board either, I think. Any markings or stickers on the back?
YouTube and Bonus
Reply 4 of 25, by Predator99
Look at #26 here:
80286 BIOS image collection
This one has 1 MB.
I think you only need to add 1 single chip to get 1 MB. The empty small sockets on the bottom right are parity I guess.
Reply 5 of 25, by muon
Although the battery is working properly (the mobo saves the date/time/settings OK) , Yes, I'm going to change it tomorrow. It's planned
Where can I get that chips or better, where can I get SIPP-modules?
Reply 6 of 25, by root42
SIPP will be tough. But you can take 30pin SIMM modules and solder pins to them...
YouTube and Bonus
Reply 7 of 25, by muon
jesolo wrote:
Have you tried this website?
http://arvutimuuseum.ee/th99/
I searched for in statong.org and I found similar boards, but not identical:
https://stason.org/TULARC/pc/motherboards/U/U … HT101A-286.html
https://stason.org/TULARC/pc/motherboards/U/U … 286-GH-286.html
https://stason.org/TULARC/pc/motherboards/U/U … MAIN-BOARD.html
Reply 8 of 25, by muon
Yes
Reply 9 of 25, by brostenen
Are you shure?
https://www.ebay.com/sch/i.html?_odkw=zipp+me … odules&_sacat=0
Reply 11 of 25, by Predator99
brostenen wrote:
Are you shure?
Not 100% sure, but I think you need to populate all 4 banks at once?
Think my proposal to add the 8. chip is the most cost effective solution to get more RAM. Dont see the kind of the chips on the photo, but 4 of these are 512kb (which are detected) and the other 3 are currently unsused.
Reply 12 of 25, by root42
brostenen wrote:
Are you shure?
Ok, wrong formulation: for the price of one SIPP module, I got four SIMM modules. I think the latter were much more ubiquitous. 😀
YouTube and Bonus
Reply 13 of 25, by muon
Predator99 wrote:
brostenen wrote:
Are you shure?
Hi again!!
I've token some pictures more closely of the chips: all chips are equals: mb81c4256-80p
I understand the motherboard has 512kb in a bank and 384 Kb in another bank. 512 kb is running but the other 384 kb is deactivated. If I buy a mb81c4256-80p and it plugs in the socket in the left botton corner and I modify the jumpers it should be 1mb the ram. is it right?
The other solution, SIPP modules, I think it's very more dificult becuase the motherboard has not label for the pin 1
Reply 14 of 25, by Predator99
muon wrote:
Hi again!!
Yes. You dont need exactly the mb81c4256-80p, there are many compatible ones...google. Dont think you have to modify jumpers for this upgrade.
Other solution:
These cards:
ISA XMS/EMS Memory Extension / Expansion cards: Now Running without Driver / Documentation :-)
..but I think they are even harder to get...
Reply 15 of 25, by muon
Hi Predator99!!
The Chips were received a few days ago. I tested yesterday... and YES I plugged one chip in the empty socket and I get 1024 KB of memory .
Now I have got another problem with the board. Here:
Right orientation SIPP module in 286 motherboard?
Reply 16 of 25, by Chr$
Sorry to dig up this old thread, but I've just ended up with a 286 that has the same motherboard (with minor differences, e.g. the CPU is Siemens branded). Back is also marked VLSI-4A 90501. It's in great shape, no battery leakage (I will remove it of course). It works and was installed so I at least know where the reset/power/speaker/turbo should go.
I assume the OP didn't find out any further info on it?
If anyone else ever does, please post here!
    1.51 MiB
Hello, I'm Chris in Saxony, Germany. Old enough to have had actual experience with 1980s Micros and 1990s PC's. Still haven't got my head round any of them!
Reply 17 of 25, by Deksor
Can you dump its bios please ? There might be useful information in there 😀
Reply 18 of 25, by Chr$
Hello Deksor. I did attempt to but the PROMS are not UV EPROMS, they are marked SDL128 and R3 T002 (both are the same I assume, but so far I've only lifted one sticker). I think the '128' part probably indicates a 27128/27C128 so I tried a couple of well known brands but it reported wrong/bad pins when trying to read.
So if you have any info on those and a suitable compatible chip to select on my Eprom programmer I will read and dump right away.
Oh, by the way, the BIOS boot screen says it's v3.03HL from Award Software Inc.
Reply 19 of 25, by Deksor
Since your board boots, you can use this 😀 http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
