Reply 27160 of 58838, by Intel486dx33
A couple of SB AWE64’s for my 486 computers.
Reply 27161 of 58838, by dionb
More goodies in the mail today:
Decent-ish NICs (well, the TI & Intel ones), but the reason I bought this was of course the G400MAX. It's Dell OEM, but 5ns SGRAM regardless. Almost 20 years ago I lusted after one of these but could only afford a crappy Jaton TNT2-M64. Good to have a second chance 😀
Reply 27162 of 58838, by luckybob
@dionb
BTW, that fan has a lian-li fan bracket still attached. Maybe someone somewhere needs one.
Reply 27163 of 58838, by appiah4
Never saw a CT4500 with colored jacks before those are probably replacements.
Reply 27164 of 58838, by bjwil1991
That is unusual. Normally, the CT4500 had the black jacks (no pun intended), and the CT4520 had the colored jacks. The reason why the person might've replaced said jacks was because they got confused which was line in, line out, mic, and spk out.
Reply 27165 of 58838, by candle_86
I'll get pics tomorrow but for 20 I got all of this
Pentium 3 800
2x128mb PC133
ASUS CUSL2
300W PSU
Soundblaster 128
Intel 10/100 Nic
ATX Case
Radeon 7000
Radeon 7500
Visiontek Geforce 2 GTS
All but the GPU's came inside the case, it posts, and all of it works flawlessly
Reply 27166 of 58838, by blurks
ATI Mach32 EISA (2048 KByte)
Reply 27167 of 58838, by 386_junkie
Ah... it was you!
Glad it be a fellow Vogon'er.
I do like EISA tech I do, especially if I can run a 386 with it.
Enjoy!
Reply 27168 of 58838, by blurks
386_junkie wrote:
Ah... it was you! Glad it be a fellow Vogon'er.
Yep and still looking for boxed examples of MCA and PCI-versions to complete the Mach32 lineup.
Reply 27169 of 58838, by Vynix
My parcel arrived, I opened it once I got home only to find a bunch of bubble wrap and newspaper (along with a note from the seller: "Have fun!", sure thing).
First I was baffled by how heavy that package was, and for a good reason, the seller included a Data8 tape drive!! An Exabyte EX-8200, that thing weights a ton!
The attachment IMG_20190209_163615.jpg is no longer available
The attachment IMG_20190209_163619.jpg is no longer available
The whole lot includes:
  • 3 SCSI 50-pin (IDE-style) cables
  • 2 hard drives: a IBM 7k2 RPM DDRS-39130 and a Hitachi UltraStar 15k RPM (!) HUS151436VL3600 HDD
  • SCSI gender changer (Centronics to HD50)
  • 2 Terminators
  • Exabyte Data8 Tape drive
  • 2 SCSI HD50 ribbon cables
  • An Adaptec AHA-2940U2W and an AVA-2904
The whole lot (the AVA-2904 isn't visible, same goes for the tape drive), because I'm too lazy to write a description for each item:
The attachment IMG_20190209_163548-min.jpg is no longer available
Reply 27170 of 58838, by Intel486dx33
Vertex VLB 2mb. graphics card for my "All USA 486 computer build".
Made in the USA.
Reply 27171 of 58838, by Tetrium
appiah4 wrote:
Finally got around to cleaning and photographing it, so here is my first SS7 motherboard, and the CPU it came with: […]
And the aforementioned warp:
No idea how people store these things to cause such bends 😕 😢 Hopefully it still works, we will see.
Also agreed on purchasing another motherboard I've been after for quite some time now, I suppose it really pours when it rains. I will post photos once I have it on hand and cleaned.
It is possible to cause warp to a board like this one by mounting a CPU with (big) HSF with powerful mounting clip, and then store it for a prolonged while.
I had this happen to a board (some cheap sA I used for testing I think) and it had warped while I had stored it away. The board still worked fine though (for a testing board), but since then I changed the habit to at least not store motherboard for any prolonged time with its CPU+HSF installed.
It does look like it warped due to the CPU+HSF having been mounted, judging from where it warped.
My retro rigs (old topic)
Report spammers here!
Reply 27172 of 58838, by arncht
Made in the USA.
yeah, korea, malaysia 😁
Overdoze of the demoscene
Reply 27173 of 58838, by Intel486dx33
arncht wrote:
Made in the USA.
They must have meant “Assembled in USA”
Reply 27174 of 58838, by PC Hoarder Patrol
Bought some NOS DDR2 performance kits for my 478, 775 & AM3+ builds
The attachment DDR2 Kits1.jpg is no longer available
The attachment DDR2 Kits2.jpg is no longer available
The attachment DDR2 Kits3.jpg is no longer available
Also, was digging thru some of the early boxes from the stuff I've recently got from a relative, and came across these AT keyboards
The attachment kbd1.jpg is no longer available
two Viglen brand Acer 6312 - top one is NIB from 1995 and the bottom one is from 1994
The attachment kbd2.jpg is no longer available
a Viglen-brand Datacomp DFK2020 - no date, but I'm guessing mid / late 90s
Reply 27175 of 58838, by Muppets4
A lovely jvc tm-h1700g video monitor. With composite and s-video connections. It lacks RGB, but makes more then up for that with 750 lines horizontal resolution. Now I have to wait until my s-video cables come in.
Image of the net:
The attachment tmh1700g.jpg is no longer available
Reply 27176 of 58838, by Bancho
Image of the net:
Nice! JVC Monitors are great. I have the JVC BM-H2000PN-K and its an awesome monitor. RGB, 750 and straight geometry!
Reply 27177 of 58838, by Merovign
Someday I will have time to set up my shipment from Liqmat's hoard. I have a case picked out for the dual PPro mobo, but here's a pic of what I consider to be my favorite bit:
The attachment N9.jpg is no longer available
Wanted one of these since they came out in the early 90s - for $2000.
But I also picked up my own mini-haul today at "cheap as chips" prices. I'm glad I skipped work last night and slept in because I burned most of my energy dealing with cars this week. These are more retro and less vintage tho:
The attachment MoboVC1.jpg is no longer available
An Epox 8K3A+, Athlon XP 2000+, and a Gf4 Ti4400. There are atrocious caps on the mobo (mostly behind the cooler) so I'll have to deal with that. No time to test now, I'll take a "test day" soon though.
The attachment VC2.jpg is no longer available
A Radeon 9250 and an 8400GS - both PCI, which will come in handy.
The attachment VC3.jpg is no longer available
MSI 8600 GTS Passive cooling and a Quadro FX 3500, which are more interesting than handy, but cool.
The attachment VCSC4.jpg is no longer available
Back side of the 8600, An ATI TV Wonder, HD 6450, and an SB Live.
Also picked up a few other things still in the car, will have to go through it later. Have to go back to work but wanted to share some of my good fortune.
*Too* *many* *things*!
Reply 27178 of 58838, by SpeedySPCFan
Another JVC monitor here in the span of a few days... yours wouldn't happen to come from Lynnwood, WA, would it? The JVC I picked up just a few days ago and posted here came from there 🤣
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
Reply 27179 of 58838, by candle_86
Got another complete system
MSI 865PE neo2-p
4gb ddr3200
GeForce 2 mx400
Pentium 4 3.2 Northwood
Fsp 350w PSU
GeForce 2 mx400 (this will go to my P3)
Dvdrom
Floppy
Traded a core2 system for it
