Reply 27380 of 58796, by Deksor
- l33t
wrote:"If I fits I ships" - cat, probably.
I have the CT4170 in my Socket 7 machine, and the CQM synth is crappy. Wish I can redirect the CQM to an external MIDI device that contains a real OPL3 chip, or swap it with an ESS AudioDrive ES1688F card.
Problem is that the CT4170 has a bug with its 16bit DMA. You can't set it to an * useful * DMA port ...
